0009448 | ParaView | Bug | public | 2009-08-24 06:54 | 2016-08-12 09:57 | ||||
Reporter | Benjamin Schindler | ||||||||
Product Version | 3.6 | ||||||||
Summary | 0009448: Paraview gives error on startup with newer nvidia drivers - opengl 1.4 deprecated | ||||||||
Description | When paraview starts, I get the following messages: bschindl@hundertwasser /local/bschindler/projects/software/flex $ paraview Generic Warning: In /var/tmp/portage/sci-visualization/paraview-3.6.1-r1/work/build/VTK/Rendering/vtkgl.cxx, line 4465 Nothing known about extension GL_VERSION_1_4_DEPRECATED. vtkgl may need to be updated. ERROR: In /var/tmp/portage/sci-visualization/paraview-3.6.1-r1/work/ParaView3/VTK/Rendering/vtkOpenGLExtensionManager.cxx, line 343 vtkOpenGLExtensionManager (0x157b240): Extension GL_VERSION_1_4 could not be loaded. I have not tested to consequences of this (may be software rendering only?) | ||||||||
Attached Files | p_scs.png [^] (38,140 bytes) 2009-09-14 09:39
(0017419) paule (reporter) 2009-09-14 09:39 |
I have the same issue and believe this is responsible for my weird screenshots, as the error messages reappear when I take one. |
(0018330) paule (reporter) 2009-11-03 11:26 |
It seems like this was a Gentoo specific problem which got fixed, see http://bugs.gentoo.org/show_bug.cgi?id=279060 [^] . |
(0037684) Kitware Robot (administrator) 2016-08-12 09:57 |
2009-08-24 06:54 | Benjamin Schindler | New Issue | |
2009-09-14 09:39 | paule | Note Added: 0017419 | |
2009-09-14 09:39 | paule | File Added: p_scs.png | |
2009-11-03 11:26 | paule | Note Added: 0018330 | |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037684 | |
2016-08-12 09:57 | Kitware Robot | Assigned To | => Kitware Robot |
