0009495 | ParaView | Feature | public | 2009-09-04 18:31 | 2010-02-22 20:19 | ||||
Target Version | 3.8 | Fixed in Version | |||||||
Summary | 0009495: (SLAC) Option to set render size to arbitrary value | ||||||||
Description | Sometimes when making screen shots or animations, it is very helpful to have the resolution match what is in the ParaView GUI (or at least be proportional in both dimensions) so that the output matches what you see. However, if you want a specific resolution in the output, it is very difficult to match in the ParaView GUI. There is already a feature to set the maximum render size to 300x300, which is used in testing. It would be handy to have a similar feature that allowed you to do the same thing so some arbitrary resolution. | ||||||||
Relationships | ||||||
(0019271) Ken Moreland (manager) 2010-01-22 11:16 |
There is now a new option called Lock View Size Custom under the Tools menu. This option behaves much like the previously existing Lock View Size option, which sets the maximum view resolution to 300x300. The difference is that this option will first pop up a dialog box to ask the user what size he/she wants. /cvsroot/ParaView3/ParaView3/Qt/ApplicationComponents/pqParaViewMenuBuilders.cxx,v <-- Qt/ApplicationComponents/pqParaViewMenuBuilders.cxx new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Qt/ApplicationComponents/pqTestingReaction.cxx,v <-- Qt/ApplicationComponents/pqTestingReaction.cxx new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/ApplicationComponents/pqTestingReaction.h,v <-- Qt/ApplicationComponents/pqTestingReaction.h new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/CMakeLists.txt,v <-- Qt/Components/CMakeLists.txt new revision: 1.178; previous revision: 1.177 /cvsroot/ParaView3/ParaView3/Qt/Components/pqLockViewSizeCustomDialog.cxx,v <-- Qt/Components/pqLockViewSizeCustomDialog.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqLockViewSizeCustomDialog.h,v <-- Qt/Components/pqLockViewSizeCustomDialog.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqViewManager.cxx,v <-- Qt/Components/pqViewManager.cxx new revision: 1.73; previous revision: 1.72 /cvsroot/ParaView3/ParaView3/Qt/Components/pqViewManager.h,v <-- Qt/Components/pqViewManager.h new revision: 1.28; previous revision: 1.27 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqLockViewSizeCustomDialog.ui,v <-- Qt/Components/Resources/UI/pqLockViewSizeCustomDialog.ui initial revision: 1.1 |
(0019590) Alan Scott (manager) 2010-02-22 20:19 |
Tested client/ remote server. Linux. Trunk. |
2009-09-04 18:31 | Ken Moreland | New Issue | |
2009-09-04 18:31 | Ken Moreland | Assigned To | => Ken Moreland |
2009-09-04 18:31 | Ken Moreland | Status | backlog => tabled |
2009-09-04 18:31 | Ken Moreland | Summary | Option to set render size to arbitrary value => (SLAC) Option to set render size to arbitrary value |
2010-01-22 11:16 | Ken Moreland | Note Added: 0019271 | |
2010-01-22 11:16 | Ken Moreland | Status | tabled => @80@ |
2010-01-22 11:16 | Ken Moreland | Resolution | open => fixed |
2010-02-08 14:56 | Ken Moreland | Relationship added | has duplicate 0010256 |
2010-02-22 20:19 | Alan Scott | Note Added: 0019590 | |
2010-02-22 20:19 | Alan Scott | Status | @80@ => closed |
