0009532 | ParaView | Bug | public | 2009-09-14 11:23 | 2016-08-12 09:57 | ||||
Assigned To | Julien Finet | ||||||||
Summary | 0009532: Scatter plot axes must be scaled independently | ||||||||
Description | Right now all the axes in a scatter plot are scaled uniformly, much like in an ordinary 2D or 3D view. This is wrong. It is important to scale each axis independently. To see an example of why, do the following: 1. Load disk_out_ref.ex2. All variables on. Apply. 2. Create a scatter plot view. Make disk_out_ref visible. 3. In the Display panel, change X Coords to Temp and Y Coords to Pres. 4. Click Reset Camera (workaround bug 0009531). Notice that all the points appear to be on a horizontal line. This is because the temperature is in Kelvins and is in the range of 200-900 whereas the pressure is in atmospheres and is in the range of 0.02-0.03. | ||||||||
(0037705) Kitware Robot (administrator) 2016-08-12 09:57 |
2009-09-14 11:23 | Ken Moreland | New Issue | |
2009-09-14 11:23 | Ken Moreland | Status | backlog => tabled |
2009-09-14 11:23 | Ken Moreland | Assigned To | => Julien Finet |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037705 | |
