0009591 | ParaView | Bug | public | 2009-09-24 15:09 | 2009-12-02 19:44 | ||||
Status | closed | Resolution | duplicate | ||||||
Target Version | 3.8 | Fixed in Version | |||||||
Summary | 0009591: Clip bounding box is in wrong location. | ||||||||
Description | Open attached file speed.inp. I used ParaView 3.6.0, local server. Clip. Notice that the clip bounding box widget is in the wrong location. It should be around our object, and slightly larger. Now, delete the clip. In the Display tab, at the bottom, change scale X, Y, Z to 1.0001. Clip. Notice that the clip bounding box is correct. Since this makes clip and slice unusable unless you know the trick, I am marking as major, for 3.8.0. | ||||||||
Attached Files | speed.inp [^] (45,449 bytes) 2009-09-24 15:10 | ||||||||
Relationships | ||||||
(0018670) Alan Scott (manager) 2009-12-02 19:44 |
Duplicate. |
2009-09-24 15:09 | Alan Scott | New Issue | |
2009-09-24 15:10 | Alan Scott | Priority | normal => high |
2009-09-24 15:10 | Alan Scott | Severity | major => minor |
2009-09-24 15:10 | Alan Scott | File Added: speed.inp | |
2009-12-02 14:14 | Utkarsh Ayachit | Status | backlog => tabled |
2009-12-02 14:14 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2009-12-02 14:15 | Utkarsh Ayachit | Relationship added | duplicate of 0009984 |
2009-12-02 14:15 | Utkarsh Ayachit | Duplicate ID | 0 => 9984 |
2009-12-02 14:15 | Utkarsh Ayachit | Status | tabled => @80@ |
2009-12-02 14:15 | Utkarsh Ayachit | Resolution | open => duplicate |
2009-12-02 19:44 | Alan Scott | Note Added: 0018670 | |
2009-12-02 19:44 | Alan Scott | Status | @80@ => closed |
