0009672 | ParaView | Feature | public | 2009-10-07 11:24 | 2010-10-27 20:48 | ||||
Assigned To | Sebastien Jourdain | ||||||||
Target Version | Fixed in Version | 3.10 | |||||||
Summary | 0009672: Separate Python tracing/macros from Python shell dialog | ||||||||
Description | Right now when you open the Python shell dialog, the dialog has attached a bunch of widgets concerning macros and Python tracing. This is too much stuff for this dialog box. The Python shell dialog should go back to being just a shell. The tracing and macro widgets should be moved to their own separate dialog box. | ||||||||
Relationships | ||||||||||||||||
(0020298) Pat Marion (reporter) 2010-04-20 17:09 |
If it makes any difference... the widgets to the side of the python shell can be collapsed using the horizontal slider, so they are not shown at all. This is remembered between sessions. |
(0022283) Pat Marion (reporter) 2010-09-20 14:12 |
If you click "show trace" and "trace state" in the trace tab, there is output that is printed to the console. If these tabs are separated from the console, maybe there should be a new text area to display the text? |
(0022284) Ken Moreland (manager) 2010-09-20 15:00 |
Showing the trace in the console seems really odd in the first place, because it is never executed even though it looks like commands. The only real reason to put it there is programmer convenience. So, yes, there should be some other text area to display the text. That text area could appear on demand. For example, pop up that Python editor with the text in it. |
(0022366) Sebastien Jourdain (manager) 2010-09-27 10:35 |
Fixed provided inside the commit 8d67360bcc130352b75f5ff8c334ca09b729cf74 - Start/Stop trace are available inside the menu now. - Edit/Save trace are available inside the menu now. - A text message keep showing in the status bar while the recording is ON. |
(0022502) Alan Scott (manager) 2010-10-15 20:37 |
I really like what has been done so far. Questions: * Why not add a "run trace" or "run memory trace" button to tools? That way, user doesn't have to write it to a file, then run it. * Why not allow a user to "run macro" in Macros, without adding? What if user wants to do this once? |
(0022659) Sebastien Jourdain (manager) 2010-10-22 10:02 |
commit d37a8cd2233b59747c285a4a348ef4952997768e Merge: f5f9a47 2d052f1 Author: Sebastien Jourdain <sebastien.jourdain@kitware.com> Date: Fri Oct 22 09:52:11 2010 -0400 Merge topic 'python-trace-ui' 2d052f1 Change strategy around Python trace usage commit 2d052f1d9ba54bbdee6cc9b89bbb8f01095adf39 Author: Sebastien Jourdain <sebastien.jourdain@kitware.com> Date: Fri Oct 22 09:43:19 2010 -0400 Change strategy around Python trace usage Now the user can only start/stop trace. When the user stop a trace, the Python editor Popup with the content of the trace. The user has to choose what he wants to do with it. He can discard it, save it as a file or save it as a Macro. Caution: As only one editor is used for Python code editing inside ParaView. If the user do not save its trace and re-run another one, when it stop it, the editor will be reset to the later trace content. The same thing happen when you try to edit a Macro while the editor is open. |
(0022719) Alan Scott (manager) 2010-10-27 20:48 |
Excellent. Tested local server, Windows, trunk. |
2009-10-07 11:24 | Ken Moreland | New Issue | |
2010-04-16 11:11 | Utkarsh Ayachit | Target Version | 3.8 => 3.10 |
2010-04-20 17:09 | Pat Marion | Note Added: 0020298 | |
2010-07-08 17:10 | Ken Moreland | Relationship added | related to 0010966 |
2010-09-01 11:17 | Utkarsh Ayachit | Relationship added | related to 0011068 |
2010-09-01 11:17 | Utkarsh Ayachit | Target Version | 3.10 => 3.10.shortlist |
2010-09-20 14:06 | Utkarsh Ayachit | Status | backlog => tabled |
2010-09-20 14:06 | Utkarsh Ayachit | Assigned To | => Sebastiennn Jourdain |
2010-09-20 14:08 | Utkarsh Ayachit | Relationship added | related to 0011251 |
2010-09-20 14:12 | Pat Marion | Note Added: 0022283 | |
2010-09-20 15:00 | Ken Moreland | Note Added: 0022284 | |
2010-09-27 10:35 | Sebastien Jourdain | Note Added: 0022366 | |
2010-09-27 10:35 | Sebastien Jourdain | Status | tabled => @80@ |
2010-09-27 10:35 | Sebastien Jourdain | Fixed in Version | => 3.10 |
2010-09-27 10:35 | Sebastien Jourdain | Resolution | open => fixed |
2010-10-15 20:37 | Alan Scott | Note Added: 0022502 | |
2010-10-15 20:37 | Alan Scott | Status | @80@ => @20@ |
2010-10-15 20:37 | Alan Scott | Resolution | fixed => reopened |
2010-10-22 10:02 | Sebastien Jourdain | Note Added: 0022659 | |
2010-10-22 10:02 | Sebastien Jourdain | Status | @20@ => @80@ |
2010-10-22 10:02 | Sebastien Jourdain | Resolution | reopened => fixed |
2010-10-27 20:48 | Alan Scott | Note Added: 0022719 | |
2010-10-27 20:48 | Alan Scott | Status | @80@ => closed |
