0009803 | ParaView | Bug | public | 2009-10-30 11:40 | 2009-12-16 19:27 | ||||
Reporter | Jerome Velut | ||||||||
Status | closed | Resolution | unable to reproduce | ||||||
Platform | PC | OS | Windows/Linux | OS Version | XP/Fedora | ||||
Summary | 0009803: Checking "Auto load" for Autostart plugins has no effect | ||||||||
Description | After loading an autostart plugin, the plugins manager shows this message: "Loaded, but MyPlugin, is not a Paraview server manager plugin!". Checking the "Auto load" check-box has no effect, ie the plugin is not loaded automatically. | ||||||||
Steps To Reproduce | Attached is a minimal build environment that triggers the bug, with REAME describing the steps. | ||||||||
Attached Files | AutoStartPluginBug.tar.bz2 [^] (1,469 bytes) 2009-10-30 11:40 | ||||||||
(0018735) Utkarsh Ayachit (administrator) 2009-12-09 10:16 |
Just tried with the example provided with ParaView in Examples. The auto-start plugin prints the "on-startup" message correctly when auto-load is enabled and ParaView restarted hence seems to be working correctly. |
(0018938) Alan Scott (manager) 2009-12-16 19:27 |
Trusting that Utkarsh tested it correctly. |
2009-10-30 11:40 | Jerome Velut | New Issue | |
2009-10-30 11:40 | Jerome Velut | File Added: AutoStartPluginBug.tar.bz2 | |
2009-12-09 10:16 | Utkarsh Ayachit | Note Added: 0018735 | |
2009-12-09 10:16 | Utkarsh Ayachit | Status | backlog => @80@ |
2009-12-09 10:16 | Utkarsh Ayachit | Resolution | open => unable to reproduce |
2009-12-09 10:16 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2009-12-16 19:27 | Alan Scott | Note Added: 0018938 | |
2009-12-16 19:27 | Alan Scott | Status | @80@ => closed |
