0009877 | ParaView | Feature | public | 2009-11-10 09:58 | 2016-08-12 09:57 | ||||
Reporter | Stephane P | ||||||||
Summary | 0009877: Preserve the representation type and other properties as filters are applied. | ||||||||
Description | When a filter is applied, the newly created representation is mostly independant from the previous one. Some parameters are preserved, but not all and it does not work with plugins. It would be nice if the newly created representation matches the parent one, when possible. This should also work in the case of representation plugins. For this, I can see two steps : 1/ When possible, create the same representation for the output as the one used for the input. 2/ copy all properties of the parent representation so that they are intially the same. | ||||||||
Project | ParaViS | ||||||||
(0023664) Utkarsh Ayachit (administrator) 2010-12-02 09:13 |
commit 32e5df406da37d7c140a425fd9572f28d862407c Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Wed Dec 1 17:12:36 2010 -0500 Inherit properties from input representation whenever possible. Partial fix for BUG 0009877. |
(0037746) Kitware Robot (administrator) 2016-08-12 09:57 |
2009-11-10 09:58 | Stephane P | New Issue | |
2010-06-15 09:10 | Utkarsh Ayachit | Target Version | => 3.8.2 |
2010-06-15 09:44 | Utkarsh Ayachit | Target Version | 3.8.2 => 3.8.1 |
2010-12-02 09:13 | Utkarsh Ayachit | Note Added: 0023664 | |
2010-12-02 10:21 | Utkarsh Ayachit | Note View State: 0023664: public | |
2011-06-23 11:44 | Utkarsh Ayachit | Project | => ParaViS |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037746 | |
2016-08-12 09:57 | Kitware Robot | Assigned To | => Kitware Robot |
