MantisBT - ParaView | |||||
| View Issue Details | |||||
| 0010137 | ParaView | Bug | public | 2010-01-13 15:35 | 2010-04-20 19:31 |
| Reporter | Eric Monson | ||||
| Assigned To | David Partyka | ||||
| Priority | normal | Severity | minor | Reproducibility | always |
| Status | closed | Resolution | fixed | ||
| Product Version | Development | ||||
| Target Version | Fixed in Version | 3.8 | |||
| Project | |||||
| Topic Name | |||||
| Type | |||||
| Summary | 0010137: Qt Widgets library link fails with Cocoa and CVS CMake | ||||
| Description | When building ParaView with CVS CMake (at least 2.9.20100105 to today's) on Mac OS X (10.6.2) with Cocoa Qt (4.6.0), libpqWidgets won't link because the Cocoa framework is not explicitly added to the linker commands. As Clinton Stimpson says, "FindQt4/UseQt don't put the extra dependencies in there anymore unless Qt is static. So if pqWidgets uses Cocoa, it needs to link against the Cocoa framework." So, at line 198 in Qt/Widgets/CMakeLists.txt, something like this needs to be added to the if(APPLE) section: if(VTK_USE_COCOA) TARGET_LINK_LIBRARIES(pqWidgets "-framework Cocoa") endif(VTK_USE_COCOA) (or using elseif, or whatever is standard...) | ||||
| Steps To Reproduce | |||||
| Relationships | |||||
| Attached Files | |||||
| Issue History | |||||
| 2010-01-13 15:35 | Eric Monson | New Issue | |||
| 2010-04-09 10:17 | David Partyka | Status | backlog => tabled | ||
| 2010-04-09 10:17 | David Partyka | Assigned To | => David Partyka | ||
| 2010-04-09 10:21 | David Partyka | Note Added: 0020109 | |||
| 2010-04-09 10:21 | David Partyka | Status | tabled => @80@ | ||
| 2010-04-09 10:21 | David Partyka | Fixed in Version | => 3.8 | ||
| 2010-04-09 10:21 | David Partyka | Resolution | open => fixed | ||
| 2010-04-20 19:31 | Alan Scott | Note Added: 0020318 | |||
| 2010-04-20 19:31 | Alan Scott | Status | @80@ => closed | ||
| Notes | |||||
