MantisBT - ParaView
View Issue Details
0010274ParaViewBugpublic2010-02-10 15:552016-08-12 09:57
Utkarsh Ayachit
Kitware Robot
normalminorhave not tried
closedmoved
Someday
0010274: zlib compression in vtkMPIMoveData is slowing client-server rendering
zlib compression in vtkMPIMoveData is slowing down data delivery considerably. Following is a timer log for can.ex2. Possible solution would be to compress only when data size is beyond a threshold.
===client====
Still Render, 1.21436 seconds
    Execute vtkMPIMoveData id: 674, 1.19688 seconds
        Zlib uncompress, 0.016727 seconds
===server====
Execute vtkMPIMoveData id: 674, 1.1723 seconds
    Dataserver sending to client, 1.17105 seconds
        Zlib compress, 1.16047 seconds
No tags attached.
related to 0009409closed Utkarsh Ayachit Use zlib compression when transferring geometry to client
pdf geometry_compression.pdf (205,911) 2010-02-15 16:07
https://www.vtk.org/Bug/file/7866/geometry_compression.pdf
Issue History
2010-02-10 15:55Utkarsh AyachitNew Issue
2010-02-10 15:56Utkarsh AyachitRelationship addedrelated to 0009409
2010-02-10 15:56Utkarsh AyachitDescription Updated
2010-02-15 16:07BurlenNote Added: 0019533
2010-02-15 16:07BurlenFile Added: geometry_compression.pdf
2010-02-15 16:11BurlenNote Edited: 0019533
2010-02-15 16:40BurlenNote Edited: 0019533
2010-02-15 16:46BurlenNote Edited: 0019533
2010-02-15 16:53BurlenNote Edited: 0019533
2010-04-16 01:37Utkarsh AyachitPriorityimmediate => normal
2010-04-16 01:37Utkarsh AyachitTarget Version3.8 => Someday
2016-08-12 09:57Kitware RobotNote Added: 0037786
2016-08-12 09:57Kitware RobotStatusexpired => closed
2016-08-12 09:57Kitware RobotResolutionopen => moved
2016-08-12 09:57Kitware RobotAssigned To => Kitware Robot
Notes
(0019533)
Burlen
2010-02-15 16:07
(edited on: 2010-02-15 16:53)
Just to clarify: The investigations (https://www.vtk.org/Bug/file/7866/geometry_compression.pdf [^]) showed at most a 2x speed up, and only for very large data and slower networks. If you are going to implement it then there are a couple of things to keep in mind:
1) geometry compression hurts performance on fast networks
2) only makes much of a difference (and at most 2x speedup) on slower networks for very large data
3) for binary floating point data, zlib compression level affects run time drastically, but higher levels don't increase the compression ratio.
I noticed that in vtkMPIMoveData the compression level is set by the compile time variable Z_DEFAULT_COMPRESSION, which is typically 6, that will kill any hopes of a speedup. You should always use zlib compression level of 1 on the binary floating point data.
Also, if you're going to compress geometry or other binary floating point data during communication you might look at LZO, it's suposed to be faster than zlib.
http://www.oberhumer.com/opensource/lzo/ [^]
I didn't do any benchmarks with LZO.
summary of benchmarks. On this data compression ratios are consistently between 1.5 and 2. localhost connection saw a slow down across the board. The 100MB network saw a speedup between 1.4 and 1.7 across the board. The broadband network saw a speed up which gradually approached 2 starting as geometry size increased passed 10kB. For both slower networks speedup increases with geometry size up to about 10MB where a plateau seems to be reached.
(0037786)
Kitware Robot
2016-08-12 09:57
Resolving issue as `moved`.
