MantisBT - ParaView | |||||
View Issue Details | |||||
0010697 | ParaView | Bug | public | 2010-05-10 10:27 | 2016-08-12 09:58 |
Reporter | Mathieu Malaterre | ||||
Priority | normal | Severity | major | Reproducibility | always |
Product Version | |||||
Project | |||||
Topic Name | |||||
Type | |||||
Summary | 0010697: Locale-dependent number format in .pvd files | ||||
Description | I have a .pvd file with entries like <DataSet timestep="9.62917e-10" group="" part="0" name="" file="./s0001:fdtd-00001.pvtu"/> If a german locale (LANG=de_DE.UTF-8) is in effect, paraview reads the timestep as the integer "9" without any diagnostic. If I replace the decimal seperator in the data file with the german ",", like this: <DataSet timestep="9,62917e-10" group="" part="0" name="" file="./s0001:fdtd-00001.pvtu"/> then paraview reads the timestep correctly. If I leave the decimal seperator in the data file as ".", but start paraview with LC_ALL=C, the timestep is also read correctly. An example dataset is attached. Note that the Calculator filter suffers from a similiar problem; any number containing a decimal point is accepted, but anything after the point is silently ignored. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2010-05-10 10:27 | Mathieu Malaterre | New Issue | |||
2010-05-10 10:29 | Mathieu Malaterre | Note Added: 0020694 | |||
2011-09-07 04:04 | Mathieu Malaterre | Assigned To | => Utkarsh Ayachit | ||
2016-08-12 09:58 | Kitware Robot | Note Added: 0037825 | |||
2016-08-12 09:58 | Kitware Robot | Status | expired => closed | ||
Notes | |||||
