MantisBT - ParaView
View Issue Details
0010815ParaViewBugpublic2010-06-10 10:342010-07-08 10:42
Utkarsh Ayachit
Utkarsh Ayachit
normalminorhave not tried
closedfixed
3.8.13.8.1
0010815: PointSpritePlugin_BUILD_EXAMPLES does not follow BUILD_EXAMPLES
From mailing list:
I have the following in my log while preparing the gentoo package
for paraview:
-- Installing: /media/anthill/portage/sci-
visualization/paraview-3.8.0/image/usr/lib/paraview-3.8/libPointSprite_Graphics.so
visualization/paraview-3.8.0/image/media/anthill/portage/sci-
visualization/paraview-3.8.0/work/ParaView-3.8.0_build/Plugins/PointSprite/PointSpriteDemo
visualization/paraview-3.8.0/image/usr/lib/paraview-3.8/libPointSprite_Plugin.so
PointSpriteDemo is the only one with that behaviour out of the stuff I checked
so far.
Also, it is an example and I have turned examples off (BUILD_EXAMPLES OFF) but
this particular one is always on, from "Plugins/PointSprite/CMakeList.txt":
set(PointSpritePlugin_BUILD_EXAMPLES ON CACHE BOOL "Build the example.")
if(PointSpritePlugin_BUILD_EXAMPLES)
   add_subdirectory(Examples)
endif(PointSpritePlugin_BUILD_EXAMPLES)
This is not consistent, if I turn off examples at the top level I expect them
to be all off.
No tags attached.
Issue History
2010-06-10 10:34Utkarsh AyachitNew Issue
2010-06-10 10:34Utkarsh AyachitStatusbacklog => tabled
2010-06-10 10:34Utkarsh AyachitAssigned To => Utkarsh Ayachit
2010-06-10 10:39Utkarsh AyachitNote Added: 0020966
2010-06-10 10:39Utkarsh AyachitStatustabled => @80@
2010-06-10 10:39Utkarsh AyachitFixed in Version => 3.8.2
2010-06-10 10:39Utkarsh AyachitResolutionopen => fixed
2010-06-15 09:44Utkarsh AyachitTarget Version3.8.2 => 3.8.1
2010-06-15 09:45Utkarsh AyachitFixed in Version3.8.2 => 3.8.1
2010-06-16 18:19Alan ScottNote Added: 0021056
2010-06-16 18:19Alan ScottStatus@80@ => closed
2010-07-07 09:55Utkarsh AyachitFixed in Version3.8.1 => Development
2010-07-07 17:16Utkarsh AyachitNote Added: 0021300
2010-07-08 10:42Utkarsh AyachitNote Deleted: 0021300
2010-07-08 10:42Utkarsh AyachitNote Added: 0021328
2010-07-08 10:42Utkarsh AyachitFixed in VersionDevelopment => 3.8.1
Notes
(0020966)
Utkarsh Ayachit
2010-06-10 10:39
commit c9af0d884532cbe472993d19a2ef6327aa9be5d8
Date: Thu Jun 10 10:38:06 2010 -0400
    Fixed BUG 0010815.
    PointSpritePlugin_BUILD_EXAMPLES is available only when BUILD_EXAMPLES is not.
    If BUILD_EXAMPLES is defined, then it is used to decide to build the point
    sprite examples.
TODO: Merge into "release" branch
(0021056)
Alan Scott
2010-06-16 18:19
Assuming Utkarsh did it correctly.
(0021328)
Utkarsh Ayachit
2010-07-08 10:42
moved to release.
