MantisBT - ParaView | ||||||||||
View Issue Details | ||||||||||
ID | Project | Category | View Status | Date Submitted | Last Update | |||||
0010835 | ParaView | Bug | public | 2010-06-16 04:44 | 2011-05-17 20:34 | |||||
Reporter | Jerome Velut | |||||||||
Assigned To | Utkarsh Ayachit | |||||||||
Priority | normal | Severity | minor | Reproducibility | always | |||||
Status | closed | Resolution | fixed | |||||||
Platform | PC | OS | Linux | OS Version | Fedora 13 | |||||
Product Version | Development | |||||||||
Target Version | Fixed in Version | 3.12 | ||||||||
Project | ||||||||||
Topic Name | ||||||||||
Type | ||||||||||
Summary | 0010835: Autoload doesn't work for XML-only plug-ins | |||||||||
Description | When enabling VTK filters in ParaView with a simple XML description of the proxy, the 'Autoload' checkbox has no effect: The plug-in has to be reloaded each time ParaView starts. | |||||||||
Steps To Reproduce | - Go to 'Tools' -> 'Manage plugins' - Click 'Load new' - Choose '*.xml' in the combobox 'Files of type' - Select the attached 'SplineFilter.xml' and press 'Ok' A SplineFilter plug-in should appear in the plug-ins list. - Click on '+' to deploy the 'SplineFilter' options - Check 'Auto Load' - Close the Plugin Manager - Close ParaView - Restart ParaView -> The SplineFilter plug-in is not loaded. | |||||||||
Additional Information | 1- It is reproducible with any XML proxy description. 2- Creating a dynamic library with ADD_PARAVIEW_PLUGIN based on that XML is a workaround, but it necessitates a build step. 3- A similar bug is described here: http://public.kitware.com/Bug/view.php?id=9803 [^] but concern binary plug-in. Thus it is not a duplicate | |||||||||
Tags | No tags attached. | |||||||||
Attached Files | ![]() https://www.vtk.org/Bug/file/8193/SplineFilter.xml | |||||||||
Issue History | ||||||||||
Date Modified | Username | Field | Change | |||||||
2010-06-16 04:44 | Jerome Velut | New Issue | ||||||||
2010-06-16 04:44 | Jerome Velut | File Added: SplineFilter.xml | ||||||||
2011-02-14 10:01 | Robert Maynard | Relationship added | related to 0010665 | |||||||
2011-02-14 16:26 | Sean Ziegeler | Note Added: 0025425 | ||||||||
2011-05-09 17:12 | Utkarsh Ayachit | Note Added: 0026472 | ||||||||
2011-05-09 17:12 | Utkarsh Ayachit | Status | backlog => @80@ | |||||||
2011-05-09 17:12 | Utkarsh Ayachit | Resolution | open => fixed | |||||||
2011-05-09 17:12 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit | |||||||
2011-05-09 17:13 | Utkarsh Ayachit | Fixed in Version | => 3.12 | |||||||
2011-05-17 20:34 | Alan Scott | Note Added: 0026526 | ||||||||
2011-05-17 20:34 | Alan Scott | Status | @80@ => closed |
Notes | |||||
