MantisBT - ParaView
View Issue Details
0011716ParaViewBugpublic2011-01-17 15:112016-08-12 09:59
Jean M. Favre
Haocheng Liu
normalmajoralways
closedmoved
ALL OS
Development
TBD
incorrect functionality
0011716: Reflect filter does not flip vectors unless there are returned by inCD->GetVectors()
I thought the usage of SetActiveVectors or SetActiveScalars() was considered obsolete in ParaView, since there cannot be more than one such DataArray at a time. Filters such as vtkReflectionFilter which do a GetVectors() to find the vector to flip ignore all other vectors which are simply copied via outPD->CopyData(inPD, i, ptId);
this is a bug, and results in wrong streamlines and all other vector displays in reflected surfaces in ParaView.
load the supplied file with vector "CF". Reflect across Z axis and display vector glyphs or streamlines. They are wrong on the reflected side.
No tags attached.
? reflect_0_0.vts (21,882) 2011-01-17 15:11
https://www.vtk.org/Bug/file/8639/reflect_0_0.vts
Issue History
2011-01-17 15:11Jean M. FavreNew Issue
2011-01-17 15:11Jean M. FavreFile Added: reflect_0_0.vts
2014-10-10 10:41Cory QuammenNote Added: 0033626
2015-08-31 07:09Menno DeijNote Added: 0035102
2015-08-31 07:09Menno DeijNote Edited: 0035102bug_revision_view_page.php?bugnote_id=35102#r1252
2016-03-16 05:44Menno DeijNote Added: 0035843
2016-07-25 15:43Haocheng LiuProject => TBD
2016-07-25 15:43Haocheng LiuType => incorrect functionality
2016-07-25 15:43Haocheng LiuAssigned To => Haocheng Liu
2016-07-25 15:43Haocheng LiuStatusbacklog => active development
2016-08-12 09:59Kitware RobotNote Added: 0038085
2016-08-12 09:59Kitware RobotStatusactive development => closed
2016-08-12 09:59Kitware RobotResolutionopen => moved
Notes
(0033626)
Cory Quammen
2014-10-10 10:41
I confirmed that this is still an issue in 4.2.
(0035102)
Menno Deij
2015-08-31 07:09
This still is an issue in origin/master.
(0035843)
Menno Deij
2016-03-16 05:44
Still an issue. It seems the origin of the problem is that the vtkDataSetAttributes::VECTORS attribute is not used properly in some readers and filters(?).
A workaround in ParaView for surface vectors is to use the Surface Vectors filter, which sets the VECTORS attribute. For volume vectors there is no such workaround.
(0038085)
Kitware Robot
2016-08-12 09:59
Resolving issue as `moved`.
