MantisBT - ParaView
View Issue Details
0011718ParaViewBugpublic2011-01-18 11:172015-01-02 10:45
Utkarsh Ayachit
Cory Quammen
normalminorhave not tried
closedno change required
Development
4.3
0011718: Slice Offsets don't work as expected.
* Wavelet
* Slice
* Delete All Offsets
* Add 10 offsets using "New Range" (default parameters).
* Apply
* delete first 2 and last 2 values. HIt apply. You'll see 6 planes. So far so good.
* now delete middle 4. Hit apply. You should see only 2 planes. You see far more.
I've verified that ParaView is calling the API correctly on vtkCutter. Looks like vtkCutter is somehow not doing the right thing.
No tags attached.
Issue History
2011-01-18 11:17Utkarsh AyachitNew Issue
2014-10-10 10:45Cory QuammenNote Added: 0033627
2014-10-10 10:45Cory QuammenStatusbacklog => gatekeeper review
2014-10-10 10:45Cory QuammenResolutionopen => no change required
2014-10-10 10:45Cory QuammenAssigned To => Cory Quammen
2014-10-15 10:08Utkarsh AyachitFixed in Version => git-master
2014-10-15 10:08Utkarsh AyachitStatusgatekeeper review => customer review
2014-10-15 10:08Utkarsh AyachitNote Added: 0033644
2014-11-06 20:11Alan ScottNote Added: 0033771
2014-11-06 20:11Alan ScottStatuscustomer review => closed
2015-01-02 10:45Utkarsh AyachitFixed in Versiongit-master => 4.3
Notes
(0033627)
Cory Quammen
2014-10-10 10:45
This appears to work as expected in 4.2.
(0033644)
Utkarsh Ayachit
2014-10-15 10:08
Topics merged into master:
        15025_fix_annotations
        15035_reverse_connections_dsrs
        15043_add_qmake_variable_back
        15044_update_example_plugins
        cmake-cmp0053-warnings
        live-breakpoint
        pv-plot-bar-lut
        visible_range
(0033771)
Alan Scott
2014-11-06 20:11
Tested as per Utkarsh's directions. Linux, local server, master.
