MantisBT - ParaView
View Issue Details
0011951ParaViewFeaturepublic2011-03-09 11:372016-08-12 09:58
David Partyka
David Partyka
normalminorhave not tried
closedmoved
3.10
0011951: Make Xdmf optional
Add build infrastructure to be able to build ParaView without Xdmf.
No tags attached.
patch 0001-Added-support-to-build-ParaView-without-Xdmf-support.patch (15,300) 2011-07-20 13:31
https://www.vtk.org/Bug/file/8984/0001-Added-support-to-build-ParaView-without-Xdmf-support.patch
patch 0001-Added-support-to-build-ParaView-without-Xdmf-support-update.patch (56,941) 2011-11-04 14:46
https://www.vtk.org/Bug/file/9065/0001-Added-support-to-build-ParaView-without-Xdmf-support-update.patch
Issue History
2011-03-09 11:37David PartykaNew Issue
2011-03-09 11:37David PartykaStatusbacklog => tabled
2011-03-09 11:37David PartykaAssigned To => David Partyka
2011-03-16 12:17David PartykaTarget Version3.10.1 => 3.10
2011-06-16 13:10Zack GalbreathCategoryFeature Request => Feature
2011-07-20 13:31Brian PannetonFile Added: 0001-Added-support-to-build-ParaView-without-Xdmf-support.patch
2011-07-20 13:32Brian PannetonNote Added: 0027032
2011-07-21 13:17David PartykaNote Added: 0027038
2011-11-04 14:46Brian PannetonFile Added: 0001-Added-support-to-build-ParaView-without-Xdmf-support-update.patch
2011-11-04 14:47Brian PannetonNote Added: 0027658
2016-08-12 09:58Kitware RobotNote Added: 0037934
2016-08-12 09:58Kitware RobotStatusbacklog => closed
2016-08-12 09:58Kitware RobotResolutionopen => moved
Notes
(0027032)
Brian Panneton
2011-07-20 13:32
I created a patch to disable the Xdmf with an option PARAVIEW_BUILD_Xdmf. It defaults to ON, so ParaView should build the same unless you change the option to OFF.
(0027038)
David Partyka
2011-07-21 13:17
Thanks Brian, when this bubbles up to the top of my queue I will take a look at your patches!
(0027658)
Brian Panneton
2011-11-04 14:47
I updated the patch to work with the git repo as of 4 Nov 2011.
(0037934)
Kitware Robot
2016-08-12 09:58
Resolving issue as `moved`.
