MantisBT - ParaView
View Issue Details
0012298ParaView(No Category)public2011-06-22 14:342012-02-08 17:27
Berk Geveci
Kyle Lutz
normalminorhave not tried
closedfixed
Development
3.123.12
Kitware
12298-use-strict-load-balancing-option
incorrect functionality
0012298: Add "Use Strict Load Balancing for Structured Data" option
Problem:
The default extent translator used by ParaView does not do the right thing with certain structured data filters - the ones that modify the extent. However, the default extent translator used by VTK causes unnecessary I/O when repartitioning data downstream. And it is not possible to fix this without significant change to bunch of filters in VTK.
Solution:
Add a "Use Strict Load Balancing for Structured Data" (GUI) option that disables the CreateTranslatorIfNecessary method in vtkSISourceProxy. This should be off by default (i.e. it does NOT disable CreateTranslatorIfNecessary) and should have a warning in its help text that this option may lead to unnecessary I/O when ParaView is run in parallel. ALSO: we should not create another extent translator when ParaView is not run in parallel.
No tags attached.
Issue History
2011-06-22 14:34Berk GeveciNew Issue
2011-06-22 14:34Berk GeveciTarget Version => 3.12
2011-07-05 16:20Utkarsh AyachitAssigned To => Kyle Lutz
2011-07-05 17:37Kyle LutzStatusbacklog => todo
2011-07-20 17:20Kyle LutzStatustodo => active development
2011-07-21 12:54Kyle LutzTopic Name => 12298-use-strict-load-balancing-option
2011-07-21 12:54Kyle LutzNote Added: 0027037
2011-07-21 12:54Kyle LutzStatusactive development => gatekeeper review
2011-07-21 12:54Kyle LutzFixed in Version => 3.12
2011-07-21 12:54Kyle LutzResolutionopen => fixed
2011-07-21 19:18Utkarsh AyachitNote Added: 0027044
2011-07-22 14:13Utkarsh AyachitStatusgatekeeper review => customer review
2011-07-22 14:13Utkarsh AyachitNote Added: 0027070
2012-02-08 17:27Utkarsh AyachitStatuscustomer review => closed
2012-02-08 17:27Utkarsh AyachitNote Added: 0028195
Notes
(0027037)
Kyle Lutz
2011-07-21 12:54
Merge topic '12298-use-strict-load-balancing-option' into next
6744f53 ENH: Add Use Strict Load Balancing setting.
(0027044)
Utkarsh Ayachit
2011-07-21 19:18
Scheduled for gatekeeper review on Jul 22, 2011 at 2 pm EDT.
(0027070)
Utkarsh Ayachit
2011-07-22 14:13
Merged to git-master.
(0028195)
Utkarsh Ayachit
2012-02-08 17:27
Closing bugs sitting in "customer review" for a long time.
