(0026898)
Ken Moreland
2011-06-27 11:07
I've noticed that there are actually two issues here. The first is that a property in the necessary server manager object disappeared so that subdivision value never makes it to the appropriate internal filter. I'm fixing that.
The second issue is that subdivision of line elements is not supported by the internal filter. Rather, only surface elements are subdivided. Thus, the fix will not have any effect on the attached test.vtk. It will, however, fix the problems with, for example, the quadraticTetra01.vtu data set (both in the ParaViewData repository and attached to this bug report for convenience). I do not intend to fix this latter problem. It is a missing feature for which I am not sure has a use case. If automatic subdivision of line elements is necessary, open a separate bug. |
(0026901)
Ken Moreland
2011-06-27 13:39
Branch 12315-display-subdivision-broken
Merged commit d7c2a66f85563e99722c24c5bd93b0b1474df0d3
(0026903)
Burlen
2011-06-27 17:36
To handle line elements (VTK_QUADRATIC_EDGE cells) a user could run the tessellate filter instead. |
(0026925)
Utkarsh Ayachit
2011-06-30 14:17
For Developers: These issues are slated for gatekeeper review on July 1, 2 pm EDT. |
(0026942)
Utkarsh Ayachit
2011-07-01 15:31
(0026945)
Utkarsh Ayachit
2011-07-02 11:06
(0026966)
Ken Moreland
2011-07-05 17:26
The bad baseline images are caused by bug 0010676, which is of too low importance to fix. Instead, I've disabled the render-server test, which invokes the problem. |
(0026968)
Ken Moreland
2011-07-05 17:29
The test on kargad seems to be failing in a place unrelated to changes in this bug. The test is successfully running, creating all 4 test images, passing the comparisons to the baseline images, and finishing. At some point either at the end of the test script or after the test script finishes a seg fault occurs.
I am reassigning the bug to Utkarsh to see if he can figure out why the seg fault happens. |
(0027005)
David Partyka
2011-07-15 14:35
Still not passing on Kargad. |
(0027047)
Utkarsh Ayachit
2011-07-21 19:18
Scheduled for gatekeeper review on Jul 22, 2011 at 2 pm EDT. |
(0027069)
Utkarsh Ayachit
2011-07-22 14:13
(0027378)
Alan Scott
2011-08-17 18:59
Tested development branch, local server, Linux client.
As stated below, now works with quadricTetra01.vtu, but not test.vtk. |
