MantisBT - ParaView | |||||
View Issue Details | |||||
0012424 | ParaView | (No Category) | public | 2011-07-28 15:56 | 2012-02-08 17:21 |
Reporter | Alan Scott | ||||
Status | closed | Resolution | fixed | ||
Product Version | |||||
Target Version | 4.0 | Fixed in Version | 3.14 | ||
Project | Sandia | ||||
Topic Name | 12424_fix_osmesa_leak | ||||
Type | crash | ||||
Summary | 0012424: Memory leak in pvbatch using --use-offscreen-rendering | ||||
Description | I have a user that is having problems with memory leaks in pvbatch, using --use-offscreen-rendering. Here is his excellent writeup: Summary: ParaView pvbatch: memory leak using --use-offscreen-rendering Notes: Create Date: 7/27/2011 6:24:05 PM I'm running into an error where the memory footprint of pvbatch keeps growing, despite the data set size remaining the same. This only occurs when using the "--use-offscreen-rendering" option in pvbatch. Unfortunately, I need that option to execute things on redsky, as the job hangs without it. This bug is present in 3.10.0 and 3.10.1 (Linux 64-bit), but is not present in 3.8.0 or 3.8.1 (Linux 64-bit). I've run this locally and on redsky and got the same results. My dataset is rather large, but I've reproduced the problem with the following simple script: --- memory.py --- from paraview.simple import * view = CreateRenderView() view.ViewSize = [700, 400] source = Sphere(PhiResolution = 1024, ThetaResolution = 1024) display = Show(source) Render() loops=20 for i in range(loops): print "on iteration %d/%d" % (i, loops) source.PhiResolution = 512 source.ThetaResolution = 512 Render() source.PhiResolution = 1024 source.ThetaResolution = 1024 Render() --- To replicate: 1) run "mpiexec -n 4 pvbatch --use-offscreen-rendering memory.py" 2) notice the memory footprint climbs to about 5 GB at the end of the script To see desired behavior: 1) run "mpiexec -n 4 pvbatch memory.py" 2) notice memory footprint never grows larger than about 1 GB If you change the number of loops to 100 or so, it'll eventually crash due to memory. Thanks, Tim | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2011-07-28 15:56 | Alan Scott | New Issue | |||
2011-08-29 18:00 | Utkarsh Ayachit | Product Version | 4.0 => | ||
2011-08-29 18:00 | Utkarsh Ayachit | Target Version | => 4.0 | ||
2011-12-05 17:54 | Utkarsh Ayachit | Note Added: 0027778 | |||
2011-12-06 07:33 | Utkarsh Ayachit | Topic Name | => 12424_fix_osmesa_leak | ||
2011-12-06 07:33 | Utkarsh Ayachit | Note Added: 0027779 | |||
2011-12-06 07:33 | Utkarsh Ayachit | Status | backlog => gatekeeper review | ||
2011-12-06 07:33 | Utkarsh Ayachit | Fixed in Version | => git-next | ||
2011-12-06 07:33 | Utkarsh Ayachit | Resolution | open => fixed | ||
2011-12-06 07:33 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit | ||
2011-12-09 14:20 | Utkarsh Ayachit | Status | gatekeeper review => customer review | ||
2011-12-09 14:20 | Utkarsh Ayachit | Note Added: 0027788 | |||
2011-12-09 14:21 | Utkarsh Ayachit | Fixed in Version | git-next => git-master | ||
2011-12-09 15:00 | Utkarsh Ayachit | Source_changeset_attached | => VTK master b292e29f | ||
2011-12-09 15:00 | Utkarsh Ayachit | Source_changeset_attached | => VTK master b6ba17e9 | ||
2011-12-09 15:00 | Utkarsh Ayachit | Source_changeset_attached | => VTK master 0f908064 | ||
2012-01-24 19:59 | Alan Scott | Note Added: 0027973 | |||
2012-01-24 19:59 | Alan Scott | Status | customer review => closed | ||
2012-02-08 17:21 | Utkarsh Ayachit | Fixed in Version | git-master => 3.14 |
Notes | |||||
