MantisBT - ParaView
View Issue Details
0012485ParaView(No Category)public2011-08-08 03:582016-08-12 09:58
Paul Melis
David Partyka
normalminorhave not tried
closedmoved
3.10.1
TBD
incorrect functionality
0012485: MPI_INCLUDE_PATH with too many paths, mpi.h not found
I'm building PV 3.8.1 and PV 3.10.1 on exactly the same Debian 6.0
system (64-bit) system using the exact same CMAKE configuration lines:
#!/bin/sh
cmake \
    -DCMAKE_BUILD_TYPE=Release \
    -DMANTA_BUILD=$HOME/c/manta-2439-build \
    -DMANTA_SOURCE=$HOME/c/manta-2439 \
    -DPARAVIEW_BUILD_PLUGIN_Manta=ON \
    -DPARAVIEW_ENABLE_PYTHON=ON \
    -DPARAVIEW_USE_MPI=ON \
    <source-dir>
The 3.8.1 build succeeds, but the 3.10.1 buid fails because mpi.h is not
being found:
[ 4%] Built target ProcessShader
[ 4%] Built target vtkMaterialLibraryConfiguredFiles
[ 5%] Built target vtkproj4
[ 5%] Built target lproj
[ 5%] Building CXX object
VTK/Utilities/mrmpi/src/CMakeFiles/MapReduceMPI.dir/mapreduce.cpp.o
/home/opti/c/ParaView-3.10.1/VTK/Utilities/mrmpi/src/mapreduce.cpp:14:17: error:
mpi.h: No such file or directory
In file included from
/home/opti/c/ParaView-3.10.1/VTK/Utilities/mrmpi/src/mapreduce.cpp:22:
/home/opti/c/ParaView-3.10.1/VTK/Utilities/mrmpi/src/mapreduce.h:38:
error: field 'MPI_Comm' has incomplete type
/home/opti/c/ParaView-3.10.1/VTK/Utilities/mrmpi/src/mapreduce.h:81:
error: 'MPI_Comm' does not name a type
/home/opti/c/ParaView-3.10.1/VTK/Utilities/mrmpi/src/mapreduce.h:93:
/home/opti/c/ParaView-3.10.1/VTK/Utilities/mrmpi/src/mapreduce.cpp:23:
/home/opti/c/ParaView-3.10.1/VTK/Utilities/mrmpi/src/keyvalue.h:36:
After the CMake (2.8.5) configuration phase MPI_INCLUDE_PATH is set
to "/usr/lib/openmpi/include;/usr/lib/openmpi/include/openmpi".
mpi.h is actually only located in /usr/lib/openmpi/include
on my system, removing the second path from MPI_INCLUDE_PATH makes
the build succeed.
No tags attached.
Issue History
2011-08-08 03:58Paul MelisNew Issue
2011-08-08 13:55David PartykaAssigned To => David Partyka
2011-11-28 07:53David DoriaNote Added: 0027733
2016-08-12 09:58Kitware RobotNote Added: 0038033
2016-08-12 09:58Kitware RobotStatusbacklog => closed
2016-08-12 09:58Kitware RobotResolutionopen => moved
Notes
(0027733)
David Doria
2011-11-28 07:53
I had this same problem (same version of CMake, same resolution).
(0038033)
Kitware Robot
2016-08-12 09:58
Resolving issue as `moved`.
