MantisBT - ParaView
View Issue Details
0012542ParaView(No Category)public2011-08-22 13:152015-01-11 08:36
Ken Moreland
Utkarsh Ayachit
highminorhave not tried
closedfixed
3.98.0
Sandia
12542_outline_interactive_mode
incorrect functionality
0012542: Client Outline Threshold should take effect when remote rendering.
The "Client Outline Threshold" option (in settings -> Render View -> Server) only takes effect when remote rendering is off. That is, if the geometry is being rendered remotely, it never uses the outline instead.
This behavior is really wrong. The point of this setting is a fallback when the interactive render is too slow. If you are dealing with large geometry (even with LOD), it might be impossible to safely set the rendering for local rendering.
When interactive remote rendering, the Client Outline Threshold should be absolute. If the geometry is above the threshold, the interactive render should be a bounding box no matter what the other settings are.
No tags attached.
Issue History
2011-08-22 13:15Ken MorelandNew Issue
2011-09-16 17:56Alan ScottProjectTBD => Sandia
2012-01-16 09:56Utkarsh AyachitAssigned To => Utkarsh Ayachit
2012-01-16 09:57Utkarsh AyachitStatusbacklog => todo
2012-05-27 22:51Utkarsh AyachitTopic Name => 12542_outline_interactive_mode
2012-05-27 22:51Utkarsh AyachitNote Added: 0028648
2012-05-28 15:10Utkarsh AyachitStatustodo => gatekeeper review
2012-05-28 15:10Utkarsh AyachitFixed in Version => git-next
2012-05-28 15:10Utkarsh AyachitResolutionopen => fixed
2012-06-01 14:40Utkarsh AyachitFixed in Versiongit-next => git-master
2012-06-01 14:41Utkarsh AyachitStatusgatekeeper review => customer review
2012-06-01 14:41Utkarsh AyachitNote Added: 0028663
2012-07-27 16:22Alan ScottNote Added: 0028962
2012-07-27 16:22Alan ScottStatuscustomer review => closed
2012-10-29 17:04Utkarsh AyachitFixed in Versiongit-master => 3.98.0
2015-01-11 08:36Utkarsh AyachitSource_changeset_attached => ParaView master c8a0f225
Notes
(0028648)
Utkarsh Ayachit
2012-05-27 22:51
commit b23749cde12643fc7cd03345b5e33b528d7cb3d3
Date: Sun May 27 22:48:19 2012 -0400
    BUG 0012542. Added support for interactive mode using outlines.
    Removing ClientOutlineThreshold - it was used to control when to deliver
    outlines to client for interactive renders. Instead, added a checkbox to the
    "LOD Parameters" dialog to indicate that when using LOD, use outlines. When
    checked, if the view decides to use LOD rendering for interactive renders (based
    on the LOD threshold), it will use outline for the LOD instead of
    quadric-clustering.
(0028663)
Utkarsh Ayachit
2012-06-01 14:41
Merged in master, if applicable.
(0028962)
Alan Scott
2012-07-27 16:22
Tested Linux, remote server, Master.
