MantisBT - ParaView | ||||||||||
View Issue Details | ||||||||||
ID | Project | Category | View Status | Date Submitted | Last Update | |||||
0012689 | ParaView | (No Category) | public | 2011-10-31 10:06 | 2013-09-03 20:39 | |||||
Reporter | len0 | |||||||||
Assigned To | Alan Scott | |||||||||
Priority | normal | Severity | minor | Reproducibility | have not tried | |||||
Status | closed | Resolution | fixed | |||||||
Platform | OS | OS Version | ||||||||
Product Version | 3.10.1 | |||||||||
Target Version | Fixed in Version | |||||||||
Project | Release | |||||||||
Topic Name | ||||||||||
Type | crash | |||||||||
Summary | 0012689: Segmentation fault when clipping Polyhedra | |||||||||
Description | Clipping an unstructured grid containing more than one polyhedron (cell type 42) in Paraview 3.10.1 64-bit and 3.12.0-RC2 64-bit yields a segmentation fault. A minimal example containing two tetrahedra is attached as .vtu file. Plane-clipping the grid with a Z-Normal should reproduce the seg. fault. The crash could also be reproduced with ParaView git/master as follows: * Load file * Filters - Clip Clip Type: Plane Origin: 0.3, 0.5, 0.5 Normal: 1, 0, 0 Tick "Inside Out" checkbox Apply (One may need to toggle the checkbox a couple of times and pressing Apply each time after toggling until the segfault gets triggered.) => 0x00007fffdf00166a in vtkDataSetSurfaceFilter::InsertPolygonInHash (this=0x2a09270, ids=0x2bd7cb0, numPts=0, sourceId=0) at /opt/ParaView3.git/VTK/Graphics/vtkDataSetSurfaceFilter.cxx:1797 1797 quad = *end; (gdb) list 1794 1789 vtkIdType* tab = new vtkIdType[numPts]; 1790 for(int i=0; i<numPts; i++) 1791 { 1792 tab[i] = ids[(offset+i)%numPts]; 1793 } 1794 1795 // Look for existing hex in the hash; 1796 end = this->QuadHash + tab[0]; 1797 quad = *end; (gdb) print numPts $1 = 0 (gdb) print tab[0] $1 = -614752568 The segfault is triggered by the variable 'numPts' being zero which causes the for-loop in line 1790 being skipped such that the array 'tab' is not initialized, but still queried at position 0 in line 1796. So, 'end' points to some random location in memory and dereferencing it in line 1797 causes the segfault. | |||||||||
Steps To Reproduce | ||||||||||
Additional Information | ||||||||||
Tags | No tags attached. | |||||||||
Attached Files | polyh_min.vtu (830) 2011-10-31 10:06 https://www.vtk.org/Bug/file/9052/polyh_min.vtu | |||||||||
Issue History | ||||||||||
Date Modified | Username | Field | Change | |||||||
2011-10-31 10:06 | len0 | New Issue | ||||||||
2011-10-31 10:06 | len0 | File Added: polyh_min.vtu | ||||||||
2013-08-19 11:58 | David Thompson | Note Added: 0031486 | ||||||||
2013-08-19 11:58 | David Thompson | Relationship added | related to 0014188 | |||||||
2013-08-20 10:39 | len0 | Note Added: 0031488 | ||||||||
2013-09-03 20:39 | Alan Scott | Note Added: 0031525 | ||||||||
2013-09-03 20:39 | Alan Scott | Status | backlog => closed | |||||||
2013-09-03 20:39 | Alan Scott | Assigned To | => Alan Scott | |||||||
2013-09-03 20:39 | Alan Scott | Resolution | open => fixed |
Notes | |||||
