MantisBT - ParaView | |||||
View Issue Details | |||||
0012852 | ParaView | (No Category) | public | 2012-01-09 11:15 | 2016-06-17 00:06 |
Reporter | td123 | ||||
Assigned To | Cory Quammen | ||||
Status | closed | Resolution | fixed | ||
Product Version | 3.12 | ||||
Target Version | Fixed in Version | 5.1 | |||
Project | TBD | ||||
Topic Name | |||||
Summary | 0012852: Paraview 3.12.0 fails to build against protobuf 2.4.1 | ||||
Description | This is a repost of http://paraview.org/Bug/view.php?id=12718 [^] since I found out how to switch project types in the bug report. If I build without protobuf installed, it passes configuration, but then later I get the error: [ 84%] Generating vtkPVMessage.pb.h, vtkPVMessage.pb.cc /build/src/ParaView-3.12.0/build/bin/protoc: error while loading shared libraries: libprotoc.so: cannot open shared object file: No such file or directory which causes: fatal error: vtkPVMessage.pb.h: No such file or directory If I install protobuf 2.4.1 on my system and try to compile, I get the following error: [ 84%] Building CXX object ParaViewCore/ServerImplementation/CMakeFiles/vtkPVServerImplementation.dir/vtkPVSessionBase.cxx.o In file included from /build/src/ParaView-3.12.0/ParaViewCore/ServerImplementation/vtkSMMessage.h:30:0, from /build/src/ParaView-3.12.0/ParaViewCore/ServerImplementation/vtkPVSessionBase.cxx:22: /build/src/ParaView-3.12.0/build/ParaViewCore/ServerImplementation/vtkPVMessage.pb.h:12:2: error: #error This file was generated by a newer version of protoc which is incompatible with your Protocol Buffer headers. Please update your headers. It seems that the configure script should be configured to add support for detecting if protobuf is installed and maybe regenerating the headers if a newer version is installed. I'm building this on archlinux. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | ![]() https://www.vtk.org/Bug/file/9099/output.txt ![]() https://www.vtk.org/Bug/file/9100/output-with-protobuf.txt | ||||
Issue History | |||||
2012-01-09 11:15 | td123 | New Issue | |||
2012-01-09 11:15 | td123 | File Added: output.txt | |||
2012-01-09 11:15 | td123 | File Added: output-with-protobuf.txt | |||
2012-02-29 01:59 | slitvinov | Note Added: 0028327 | |||
2015-04-30 11:51 | Orion Poplawski | Note Added: 0034390 | |||
2016-05-06 10:19 | Cory Quammen | Note Added: 0035928 | |||
2016-05-06 10:19 | Cory Quammen | Status | backlog => gatekeeper review | ||
2016-05-06 10:19 | Cory Quammen | Resolution | open => fixed | ||
2016-05-06 10:19 | Cory Quammen | Assigned To | => Cory Quammen | ||
2016-06-17 00:06 | Utkarsh Ayachit | Status | gatekeeper review => customer review | ||
2016-06-17 00:06 | Utkarsh Ayachit | Fixed in Version | => 5.1 | ||
2016-06-17 00:06 | Utkarsh Ayachit | Status | customer review => closed |
Notes | |||||
