MantisBT - ParaView |
| View Issue Details |
| 0012937 | ParaView | (No Category) | public | 2012-02-14 13:13 | 2013-01-10 22:45 |
| Reporter | Sebastien Jourdain | |
| Assigned To | Sebastien Jourdain | |
| Priority | normal | Severity | minor | Reproducibility | have not tried |
| Status | closed | Resolution | fixed | |
| Platform | | OS | | OS Version | |
| Product Version | | |
| Target Version | | Fixed in Version | 3.98.0 | |
| Project | TBD |
| Topic Name | 12937-undo-redo-zoom-to-box |
| Type | incorrect functionality |
| Summary | 0012937: Undo Redo not working for "Zoom to Box" action |
| Description | When the camera is modified each position is stored in a custom undo stack which is not the case when we call the "Zoom to Box" function. |
| Steps To Reproduce | |
| Additional Information | |
| Tags | No tags attached. |
| Relationships | |
| Attached Files | |
| Issue History |
| 2012-02-14 13:13 | Sebastien Jourdain | New Issue | |
| 2012-02-14 13:13 | Sebastien Jourdain | Assigned To | => Sebastiennn Jourdain |
| 2012-02-14 13:13 | Sebastien Jourdain | Status | backlog => todo |
| 2012-02-14 13:14 | Sebastien Jourdain | Status | todo => active development |
| 2012-02-14 14:13 | Sebastien Jourdain | Topic Name | => 12937-undo-redo-zoom-to-box |
| 2012-02-14 14:13 | Sebastien Jourdain | Status | active development => gatekeeper review |
| 2012-02-14 14:13 | Sebastien Jourdain | Resolution | open => fixed |
| 2012-02-17 12:22 | Utkarsh Ayachit | Fixed in Version | => git-master |
| 2012-02-17 12:22 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2012-02-17 12:22 | Utkarsh Ayachit | Note Added: 0028286 | |
| 2012-02-20 10:28 | Utkarsh Ayachit | Fixed in Version | git-master => 3.14 |
| 2012-04-12 20:51 | Alan Scott | Note Added: 0028471 | |
| 2012-07-18 20:51 | Alan Scott | Note Added: 0028813 | |
| 2012-07-18 20:51 | Alan Scott | Note Added: 0028814 | |
| 2012-07-18 20:51 | Alan Scott | Status | customer review => todo |
| 2012-07-19 08:18 | Sebastien Jourdain | Note Added: 0028841 | |
| 2012-07-19 08:50 | Sebastien Jourdain | Note Added: 0028843 | |
| 2012-10-30 09:11 | Sebastien Jourdain | Note Added: 0029593 | |
| 2012-10-30 09:11 | Sebastien Jourdain | Status | todo => gatekeeper review |
| 2012-10-31 10:46 | Utkarsh Ayachit | Fixed in Version | 3.14 => 3.98.0 |
| 2012-10-31 10:47 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2012-10-31 10:47 | Utkarsh Ayachit | Note Added: 0029611 | |
| 2013-01-10 22:45 | Alan Scott | Note Added: 0030092 | |
| 2013-01-10 22:45 | Alan Scott | Status | customer review => closed |
(0028286)
Utkarsh Ayachit
2012-02-17 12:22
Merged into git-master, if applicable. |
(0028471)
Alan Scott
2012-04-12 20:51
I just tested this, and it works with undo, but fails with redo. Alan. |
(0028813)
Alan Scott
2012-07-18 20:51
This now doesn't undo at all. |
(0028814)
Alan Scott
2012-07-18 20:51
(0028841)
Sebastien Jourdain
2012-07-19 08:18
Hi Alan,
camera changes are not and should not be recorded in the regular Undo/Redo. Instead they are managed by the camera undo/redo that you can find on top of each window toolbar. And that's what is happening with the "Zoom to box" action, you can not Undo them, unless you undo by using those set of window related toolbar button.
Although, while double checking this morning, I've noticed that some RenderView related change get recorded, which seems to be a bug.
Please let me know if you still think it is not working. |
(0028843)
Sebastien Jourdain
2012-07-19 08:50
Ok I've fixed some of the unwanted behavior here: http://www.paraview.org/Bug/view.php?id=13313 [^]
BUT, "Zoom to box" change the center of rotation (I don't know if this is intended or not), and that change get recorded in the main undo/redo stack as it is not a camera position related change.
So depending on what is expected for "Zoom to box" and the "Center of rotation", the behavior is the way it is supposed to be now. |
(0029593)
Sebastien Jourdain
2012-10-30 09:11
Move forward to customer review.... |
(0029611)
Utkarsh Ayachit
2012-10-31 10:47
merged into master, if applicable. |
(0030092)
Alan Scott
2013-01-10 22:45
Seems to work correctly.
Tested local server, Windows, master. |
