MantisBT - ParaView
View Issue Details
0012972ParaView(No Category)public2012-03-01 11:512013-05-18 20:00
Burlen
Robert Maynard
highminorhave not tried
closedfixed
3.14
4.0
TBD
duplicate_visit_symbols
incorrect functionality
0012972: duplicated symbols VisIt bridge and PointSprite plugin static linking
PointSprite plugin and VisIt bridge duplicate have some symbols see ld error output below. This is an important problem because it prevents a static server build from being compatible with KW provided client binaries.
#!/bin/bash
cmake \
   -DCMAKE_BUILD_TYPE=Debug \
   -DBUILD_SHARED_LIBS=OFF \
   -DBUILD_TESTING=ON \
   -DBOOST_ROOT=/work/ext/ParaView/boost_1_47_0 \
   -DVTK_USE_BOOST=ON \
   -DPARAVIEW_ENABLE_PYTHON=OFF \
   -DPARAVIEW_USE_MPI=ON \
   -DPARAVIEW_USE_VISITBRIDGE=ON \
   -DVISIT_BUILD_READER_CGNS=OFF \
   -DVISIT_BUILD_READER_Silo=OFF \
Linking CXX executable ../bin/pvdataserver
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `EqualVal<AttributeGroup*>::EqualVector(void*, void*)':
/usr/include/c++/4.4/new:101: multiple definition of `EqualVal<AttributeGroup*>::EqualVector(void*, void*)'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/usr/include/c++/4.4/new:101: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `ConstInterp<AttributeGroup*>::InterpVector(void*, void*, void*, double)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/utility/Interpolator.h:186: multiple definition of `ConstInterp<AttributeGroup*>::InterpVector(void*, void*, void*, double)'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/Interpolator.h:185: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `LinInterp<int>::InterpScalar(void*, void*, void*, double)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/utility/Interpolator.h:296: multiple definition of `LinInterp<int>::InterpScalar(void*, void*, void*, double)'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/Interpolator.h:295: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `LinInterp<int>::InterpArray(void*, void*, void*, int, double)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/utility/Interpolator.h:306: multiple definition of `LinInterp<int>::InterpArray(void*, void*, void*, int, double)'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/Interpolator.h:305: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `LinInterp<int>::InterpVector(void*, void*, void*, double)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/utility/Interpolator.h:317: multiple definition of `LinInterp<int>::InterpVector(void*, void*, void*, double)'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/Interpolator.h:316: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `LinInterp<AttributeGroup*>::InterpVector(void*, void*, void*, double)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/utility/Interpolator.h:359: multiple definition of `LinInterp<AttributeGroup*>::InterpVector(void*, void*, void*, double)'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/Interpolator.h:358: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:137: multiple definition of `AttributeGroup::AttributeGroup(char const*)'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:128: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::CreateTypeMap(char const*)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2256: multiple definition of `AttributeGroup::CreateTypeMap(char const*)'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2222: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `~AttributeGroup':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:156: multiple definition of `AttributeGroup::~AttributeGroup()'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:147: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::NumAttributes() const':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:177: multiple definition of `AttributeGroup::NumAttributes() const'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:168: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::IsSelected(int) const':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:208: multiple definition of `AttributeGroup::IsSelected(int) const'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:199: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::CopyAttributes(AttributeGroup const*)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:239: multiple definition of `AttributeGroup::CopyAttributes(AttributeGroup const*)'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:230: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::InterpolateConst(AttributeGroup const*, AttributeGroup const*, double)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:281: multiple definition of `AttributeGroup::InterpolateConst(AttributeGroup const*, AttributeGroup const*, double)'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:269: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::InterpolateLinear(AttributeGroup const*, AttributeGroup const*, double)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:446: multiple definition of `AttributeGroup::InterpolateLinear(AttributeGroup const*, AttributeGroup const*, double)'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:423: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::EqualTo(AttributeGroup const*) const':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:603: multiple definition of `AttributeGroup::EqualTo(AttributeGroup const*) const'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:566: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::TypeName() const':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:754: multiple definition of `AttributeGroup::TypeName() const'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:711: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::CreateSubAttributeGroup(int)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:1418: multiple definition of `AttributeGroup::CreateSubAttributeGroup(int)'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:1402: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::Select(int, void*, int)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:1445: multiple definition of `AttributeGroup::Select(int, void*, int)'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:1429: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::SelectField(int)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:1472: multiple definition of `AttributeGroup::SelectField(int)'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:1456: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::SelectFields(std::vector<int, std::allocator<int> > const&)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:1498: multiple definition of `AttributeGroup::SelectFields(std::vector<int, std::allocator<int> > const&)'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:1482: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::UnSelectAll()':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:1530: multiple definition of `AttributeGroup::UnSelectAll()'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:1514: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::CreateNode(DataNode*, bool, bool)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:1564: multiple definition of `AttributeGroup::CreateNode(DataNode*, bool, bool)'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:1548: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::SetFromNode(DataNode*)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:1585: multiple definition of `AttributeGroup::SetFromNode(DataNode*)'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:1569: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::ProcessOldVersions(DataNode*, char const*)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:1609: multiple definition of `AttributeGroup::ProcessOldVersions(DataNode*, char const*)'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:1593: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::VersionLessThan(char const*, char const*)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:1640: multiple definition of `AttributeGroup::VersionLessThan(char const*, char const*)'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:1624: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::NumAttributesSelected() const':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:1823: multiple definition of `AttributeGroup::NumAttributesSelected() const'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:1807: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareChar()':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2064: multiple definition of `AttributeGroup::DeclareChar()'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2039: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `typeInfo':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2415: multiple definition of `AttributeGroup::typeInfo::typeInfo(unsigned char)'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2378: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `~typeInfo':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2423: multiple definition of `AttributeGroup::typeInfo::~typeInfo()'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2386: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareUnsignedChar()':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2069: multiple definition of `AttributeGroup::DeclareUnsignedChar()'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2044: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareInt()':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2074: multiple definition of `AttributeGroup::DeclareInt()'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2049: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareLong()':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2080: multiple definition of `AttributeGroup::DeclareLong()'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2055: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareFloat()':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2086: multiple definition of `AttributeGroup::DeclareFloat()'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2061: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareDouble()':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2092: multiple definition of `AttributeGroup::DeclareDouble()'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2067: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareString()':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2098: multiple definition of `AttributeGroup::DeclareString()'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2073: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareAttributeGroup()':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2104: multiple definition of `AttributeGroup::DeclareAttributeGroup()'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2079: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareBool()':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2110: multiple definition of `AttributeGroup::DeclareBool()'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2085: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareListChar()':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2116: multiple definition of `AttributeGroup::DeclareListChar()'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2091: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareListUnsignedChar()':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2122: multiple definition of `AttributeGroup::DeclareListUnsignedChar()'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2097: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareListInt()':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2128: multiple definition of `AttributeGroup::DeclareListInt()'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2103: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareListLong()':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2134: multiple definition of `AttributeGroup::DeclareListLong()'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2109: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareListFloat()':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2140: multiple definition of `AttributeGroup::DeclareListFloat()'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2115: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareListDouble()':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2146: multiple definition of `AttributeGroup::DeclareListDouble()'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2121: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareListString()':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2152: multiple definition of `AttributeGroup::DeclareListString()'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2127: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareListAttributeGroup()':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2158: multiple definition of `AttributeGroup::DeclareListAttributeGroup()'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2133: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareListBool()':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2164: multiple definition of `AttributeGroup::DeclareListBool()'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2139: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareVectorBool()':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2170: multiple definition of `AttributeGroup::DeclareVectorBool()'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2145: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareVectorChar()':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2176: multiple definition of `AttributeGroup::DeclareVectorChar()'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2151: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareVectorUnsignedChar()':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2182: multiple definition of `AttributeGroup::DeclareVectorUnsignedChar()'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2157: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareVectorInt()':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2188: multiple definition of `AttributeGroup::DeclareVectorInt()'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2163: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareVectorLong()':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2194: multiple definition of `AttributeGroup::DeclareVectorLong()'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2169: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareVectorFloat()':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2200: multiple definition of `AttributeGroup::DeclareVectorFloat()'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2175: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareVectorDouble()':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2206: multiple definition of `AttributeGroup::DeclareVectorDouble()'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2181: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareVectorAttributeGroup()':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2212: multiple definition of `AttributeGroup::DeclareVectorAttributeGroup()'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2187: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::DeclareVectorString()':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2218: multiple definition of `AttributeGroup::DeclareVectorString()'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2193: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::SetGuido(int)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2389: multiple definition of `AttributeGroup::SetGuido(int)'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2352: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::GetGuido()':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2395: multiple definition of `AttributeGroup::GetGuido()'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2358: first defined here
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2399: multiple definition of `AttributeGroup::typeInfo::typeInfo()'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2362: first defined here
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2407: multiple definition of `AttributeGroup::typeInfo::typeInfo(AttributeGroup::typeInfo const&)'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2370: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::typeInfo::operator=(AttributeGroup::typeInfo const&)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2429: multiple definition of `AttributeGroup::typeInfo::operator=(AttributeGroup::typeInfo const&)'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2392: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::GetFieldName(int) const':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2438: multiple definition of `AttributeGroup::GetFieldName(int) const'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2401: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::GetFieldType(int) const':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2444: multiple definition of `AttributeGroup::GetFieldType(int) const'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2407: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::GetFieldTypeName(int) const':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2475: multiple definition of `AttributeGroup::GetFieldTypeName(int) const'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2413: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `AttributeGroup::FieldsEqual(int, AttributeGroup const*) const':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2535: multiple definition of `AttributeGroup::FieldsEqual(int, AttributeGroup const*) const'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2419: first defined here
../bin/libvisitcommon.a(AttributeGroup.C.o): In function `operator<<(std::basic_ostream<char, std::char_traits<char> >&, AttributeGroup const&)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/AttributeGroup.C:2571: multiple definition of `operator<<(std::basic_ostream<char, std::char_traits<char> >&, AttributeGroup const&)'
../bin/libPointSprite_Plugin.a(AttributeGroup.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/AttributeGroup.cpp:2452: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode':
/usr/include/c++/4.4/new:101: multiple definition of `DataNode::bogusString'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/usr/include/c++/4.4/new:101: first defined here
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:70: multiple definition of `DataNode::bogusCharVector'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:68: first defined here
(.bss+0x30): multiple definition of `DataNode::bogusUnsignedCharVector'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):(.bss+0x30): first defined here
/usr/include/c++/4.4/bits/stl_algobase.h:381: multiple definition of `DataNode::bogusIntVector'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/usr/include/c++/4.4/bits/stl_algobase.h:381: first defined here
/usr/include/c++/4.4/bits/stl_vector.h:116: multiple definition of `DataNode::bogusLongVector'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/usr/include/c++/4.4/bits/stl_vector.h:116: first defined here
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:77: multiple definition of `DataNode::bogusFloatVector'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:75: first defined here
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:77: multiple definition of `DataNode::bogusDoubleVector'
/usr/include/c++/4.4/bits/stl_uninitialized.h:81: multiple definition of `DataNode::bogusStringVector'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/usr/include/c++/4.4/bits/stl_uninitialized.h:81: first defined here
/usr/include/c++/4.4/new:101: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:70: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:77: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, char)'
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:84: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned char)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:82: first defined here
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:91: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, int)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:89: first defined here
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:98: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, long)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:96: first defined here
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:105: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, float)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:103: first defined here
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:112: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, double)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:110: first defined here
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:119: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:117: first defined here
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:126: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:124: first defined here
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:133: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, char const*, int)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:131: first defined here
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:146: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned char const*, int)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:144: first defined here
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:159: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, int const*, int)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:157: first defined here
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:172: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, long const*, int)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:170: first defined here
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:185: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, float const*, int)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:183: first defined here
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:198: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, double const*, int)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:196: first defined here
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:211: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const*, int)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:209: first defined here
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:226: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool const*, int)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:224: first defined here
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:239: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::vector<char, std::allocator<char> > const&)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:237: first defined here
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:246: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::vector<unsigned char, std::allocator<unsigned char> > const&)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:244: first defined here
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:253: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::vector<int, std::allocator<int> > const&)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:251: first defined here
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:260: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::vector<long, std::allocator<long> > const&)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:258: first defined here
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:267: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::vector<float, std::allocator<float> > const&)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:265: first defined here
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:274: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::vector<double, std::allocator<double> > const&)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:272: first defined here
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:281: multiple definition of `DataNode::DataNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::vector<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:279: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `~DataNode':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:307: multiple definition of `DataNode::~DataNode()'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:305: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::FreeData()':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:327: multiple definition of `DataNode::FreeData()'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:325: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsChar() const':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:509: multiple definition of `DataNode::AsChar() const'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:507: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsUnsignedChar() const':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:515: multiple definition of `DataNode::AsUnsignedChar() const'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:513: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsInt() const':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:521: multiple definition of `DataNode::AsInt() const'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:519: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsLong() const':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:527: multiple definition of `DataNode::AsLong() const'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:525: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsFloat() const':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:533: multiple definition of `DataNode::AsFloat() const'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:531: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsDouble() const':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:544: multiple definition of `DataNode::AsDouble() const'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:542: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsString() const':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:555: multiple definition of `DataNode::AsString() const'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:553: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsBool() const':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:564: multiple definition of `DataNode::AsBool() const'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:562: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsCharArray() const':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:570: multiple definition of `DataNode::AsCharArray() const'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:568: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsUnsignedCharArray() const':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:576: multiple definition of `DataNode::AsUnsignedCharArray() const'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:574: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsIntArray() const':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:582: multiple definition of `DataNode::AsIntArray() const'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:580: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsLongArray() const':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:588: multiple definition of `DataNode::AsLongArray() const'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:586: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsFloatArray() const':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:594: multiple definition of `DataNode::AsFloatArray() const'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:592: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsDoubleArray() const':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:600: multiple definition of `DataNode::AsDoubleArray() const'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:598: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsStringArray() const':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:606: multiple definition of `DataNode::AsStringArray() const'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:604: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsBoolArray() const':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:612: multiple definition of `DataNode::AsBoolArray() const'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:610: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsCharVector() const':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:618: multiple definition of `DataNode::AsCharVector() const'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:616: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsUnsignedCharVector() const':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:627: multiple definition of `DataNode::AsUnsignedCharVector() const'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:625: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsIntVector() const':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:636: multiple definition of `DataNode::AsIntVector() const'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:634: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsLongVector() const':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:645: multiple definition of `DataNode::AsLongVector() const'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:643: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsFloatVector() const':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:654: multiple definition of `DataNode::AsFloatVector() const'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:652: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsDoubleVector() const':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:663: multiple definition of `DataNode::AsDoubleVector() const'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:661: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AsStringVector() const':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:672: multiple definition of `DataNode::AsStringVector() const'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:670: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetChar(char)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:685: multiple definition of `DataNode::SetChar(char)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:683: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetUnsignedChar(unsigned char)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:693: multiple definition of `DataNode::SetUnsignedChar(unsigned char)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:691: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetInt(int)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:701: multiple definition of `DataNode::SetInt(int)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:699: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetLong(long)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:709: multiple definition of `DataNode::SetLong(long)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:707: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetFloat(float)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:717: multiple definition of `DataNode::SetFloat(float)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:715: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetDouble(double)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:725: multiple definition of `DataNode::SetDouble(double)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:723: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetString(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:733: multiple definition of `DataNode::SetString(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:731: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetBool(bool)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:741: multiple definition of `DataNode::SetBool(bool)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:739: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetCharArray(char const*, int)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:749: multiple definition of `DataNode::SetCharArray(char const*, int)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:747: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetUnsignedCharArray(unsigned char const*, int)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:764: multiple definition of `DataNode::SetUnsignedCharArray(unsigned char const*, int)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:762: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetIntArray(int const*, int)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:779: multiple definition of `DataNode::SetIntArray(int const*, int)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:777: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetLongArray(long const*, int)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:794: multiple definition of `DataNode::SetLongArray(long const*, int)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:792: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetFloatArray(float const*, int)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:809: multiple definition of `DataNode::SetFloatArray(float const*, int)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:807: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetDoubleArray(double const*, int)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:824: multiple definition of `DataNode::SetDoubleArray(double const*, int)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:822: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetStringArray(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const*, int)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:839: multiple definition of `DataNode::SetStringArray(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const*, int)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:837: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetBoolArray(bool const*, int)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:856: multiple definition of `DataNode::SetBoolArray(bool const*, int)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:854: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetCharVector(std::vector<char, std::allocator<char> > const&)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:871: multiple definition of `DataNode::SetCharVector(std::vector<char, std::allocator<char> > const&)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:869: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetUnsignedCharVector(std::vector<unsigned char, std::allocator<unsigned char> > const&)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:879: multiple definition of `DataNode::SetUnsignedCharVector(std::vector<unsigned char, std::allocator<unsigned char> > const&)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:877: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetIntVector(std::vector<int, std::allocator<int> > const&)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:887: multiple definition of `DataNode::SetIntVector(std::vector<int, std::allocator<int> > const&)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:885: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetLongVector(std::vector<long, std::allocator<long> > const&)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:895: multiple definition of `DataNode::SetLongVector(std::vector<long, std::allocator<long> > const&)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:893: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetFloatVector(std::vector<float, std::allocator<float> > const&)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:903: multiple definition of `DataNode::SetFloatVector(std::vector<float, std::allocator<float> > const&)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:901: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetDoubleVector(std::vector<double, std::allocator<double> > const&)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:911: multiple definition of `DataNode::SetDoubleVector(std::vector<double, std::allocator<double> > const&)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:909: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetStringVector(std::vector<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:919: multiple definition of `DataNode::SetStringVector(std::vector<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:917: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::AddNode(DataNode*)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:1068: multiple definition of `DataNode::AddNode(DataNode*)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:1010: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::RemoveNode(DataNode*, bool)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:1117: multiple definition of `DataNode::RemoveNode(DataNode*, bool)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:1059: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::RemoveNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:1186: multiple definition of `DataNode::RemoveNode(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:1128: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::GetKey() const':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:1241: multiple definition of `DataNode::GetKey() const'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:1183: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::SetKey(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:1247: multiple definition of `DataNode::SetKey(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:1189: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::GetNodeType() const':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:1253: multiple definition of `DataNode::GetNodeType() const'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:1195: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::GetLength() const':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:1259: multiple definition of `DataNode::GetLength() const'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:1201: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::GetNumChildren() const':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:1265: multiple definition of `DataNode::GetNumChildren() const'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:1207: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::GetNumChildObjects() const':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:1284: multiple definition of `DataNode::GetNumChildObjects() const'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:1226: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `DataNode::GetChildren()':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:1322: multiple definition of `DataNode::GetChildren()'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:1264: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `NodeTypeName(NodeTypeEnum)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:1352: multiple definition of `NodeTypeName(NodeTypeEnum)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:1294: first defined here
../bin/libvisitcommon.a(DataNode.C.o): In function `GetNodeType(char const*)':
/work/ext/ParaView/ParaView-3.14.0-Source/Utilities/VisItBridge/common/state/DataNode.C:1373: multiple definition of `GetNodeType(char const*)'
../bin/libPointSprite_Plugin.a(DataNode.cpp.o):/work/ext/ParaView/ParaView-3.14.0-Source/Plugins/PointSprite/ParaViewPlugin/Qvis/DataNode.cpp:1315: first defined here
collect2: ld returned 1 exit status
make[2]: *** [bin/pvdataserver] Error 1
make[1]: *** [CommandLineExecutables/CMakeFiles/pvdataserver.dir/all] Error 2
make: *** [all] Error 2
No tags attached.
Issue History
2012-03-01 11:51BurlenNew Issue
2012-08-27 09:06Utkarsh AyachitNote Added: 0029072
2012-08-27 09:06Utkarsh AyachitNote Edited: 0029072bug_revision_view_page.php?bugnote_id=29072#r469
2013-04-17 17:41Robert MaynardAssigned To => Robert Maynard
2013-04-17 17:42Robert MaynardStatusbacklog => todo
2013-04-17 17:42Robert MaynardStatustodo => active development
2013-04-18 08:59Robert MaynardTopic Name => duplicate_visit_symbols
2013-04-18 08:59Robert MaynardStatusactive development => gatekeeper review
2013-04-18 08:59Robert MaynardResolutionopen => fixed
2013-04-19 14:07Utkarsh AyachitFixed in Version => git-master
2013-04-19 14:07Utkarsh AyachitStatusgatekeeper review => customer review
2013-04-19 14:07Utkarsh AyachitNote Added: 0030584
2013-04-30 20:43Alan ScottNote Added: 0030655
2013-04-30 20:43Alan ScottStatuscustomer review => closed
2013-05-18 20:00Utkarsh AyachitFixed in Versiongit-master => 4.0
Notes
(0029072)
Utkarsh Ayachit
2012-08-27 09:06
Temporarily, this is overcome by automatically disabling PointSprite plugin compilation when VisIt bridge is ON in git-master.
(0030584)
Utkarsh Ayachit
2013-04-19 14:07
SUMMARY
Topics merged into master:
        13060_update_netkarreaderplugin
        13842_fix_camera_link_state_loading
        14007-add_space_navigator_grab_world_style
        14009_MaterialInterfaceFilter_improvement
        14010_catalyst_documentation
        cgns_steady_state
        pvw-fix-doc-external-link
        pvw-fix-install-rules
(0030655)
Alan Scott
2013-04-30 20:43
Burlen,
If this isn't a good enough answer (see Utkarsh's reply below), please reopen this bug.
