MantisBT - VTK | |||||
View Issue Details | |||||
0012994 | VTK | (No Category) | public | 2012-03-14 03:58 | 2015-01-09 13:53 |
Reporter | nikolay.zhavoronok | ||||
Status | closed | Resolution | fixed | ||
Product Version | 5.8.0 | ||||
Target Version | Fixed in Version | 6.0.0 | |||
Project | TBD | ||||
Summary | 0012994: vtkXMLMultiBlockDataWriter does not write names for leaf nodes of the multiblock dataset | ||||
Description | The following code will assign the name for 0 block, but will not write this name into vtu file: ============================================ vtkNew<vtkUnstructuredGrid> ugrid; vtkNew<vtkMultiBlockDataSet> mb; mb->SetNumberOfBlocks( 1 ); mb->SetBlock( 0, ugrid.GetPointer() ); mb->GetMetaData( 0 )->Set(vtkCompositeDataSet::NAME(), "My Material 1"); mb->GetMetaData( 0 )->Print( std::cout ); // for debuggin to see the name vtkXMLMultiBlockDataWriter *writer = vtkXMLMultiBlockDataWriter::New(); writer->SetInput( mb.GetPointer() ); writer->SetFileName("test.vtm"); writer->Write(); ============================================ The problem is inside vtkXMLMultiBlockDataWriter.cxx, int vtkXMLMultiBlockDataWriter::WriteComposite method iterates over multiblock data set items, and writes names only for vtkCompositeDataSet datasets. The fix looks easy, I am attaching the fixed file. VTK Reader & Paraview support reading of leaf dataset names correctly, so the problem is only in writer. Thanks, Nikolay | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | ![]() https://www.vtk.org/Bug/file/9132/vtkXMLMultiBlockDataWriter.cxx | ||||
Issue History | |||||
2012-03-14 03:58 | nikolay.zhavoronok | New Issue | |||
2012-03-14 03:58 | nikolay.zhavoronok | File Added: vtkXMLMultiBlockDataWriter.cxx | |||
2012-03-29 17:10 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit | ||
2012-03-29 17:10 | Utkarsh Ayachit | Status | backlog => tabled | ||
2012-03-29 17:22 | Utkarsh Ayachit | Note Added: 0028407 | |||
2012-03-29 17:23 | Utkarsh Ayachit | Note Added: 0028408 | |||
2012-03-29 17:23 | Utkarsh Ayachit | Status | tabled => gatekeeper review | ||
2012-03-29 17:23 | Utkarsh Ayachit | Resolution | open => fixed | ||
2013-05-17 13:53 | Utkarsh Ayachit | Note Added: 0030795 | |||
2013-07-22 19:39 | Dave DeMarle | Status | gatekeeper review => closed | ||
2013-07-22 19:39 | Dave DeMarle | Fixed in Version | => 6.0.0 | ||
2015-01-09 13:48 | Utkarsh Ayachit | Source_changeset_attached | => VTK master 77b0673c | ||
2015-01-09 13:48 | Utkarsh Ayachit | Source_changeset_attached | => VTK master 3a192370 | ||
2015-01-09 13:53 | Utkarsh Ayachit | Source_changeset_attached | => VTK master 3f2b5202 |
Notes | |||||
