MantisBT - ParaView |
| View Issue Details |
| 0013072 | ParaView | (No Category) | public | 2012-04-10 10:47 | 2012-10-29 17:04 |
| Reporter | Utkarsh Ayachit | |
| Assigned To | Sebastien Jourdain | |
| Priority | normal | Severity | minor | Reproducibility | have not tried |
| Status | closed | Resolution | fixed | |
| Platform | | OS | | OS Version | |
| Product Version | git-next | |
| Target Version | | Fixed in Version | 3.98.0 | |
| Project | INL |
| Topic Name | 13072-plot-over-line-on-1D-ds |
| Type | incorrect functionality |
| Summary | 0013072: Plot over line doesn't work with 1d datasets |
| Description | If I've read in a 1D result (all elements are edges) with gaps it is impossible to get the "Plot over line" tool to pick up the values. I've attached an Exodus file (out_displaced.e) that shows the phenomenon. I would like to do do one "plot over line" that encompasses both pieces (with the value being zero between them). |
| Steps To Reproduce | |
| Additional Information | |
| Tags | No tags attached. |
| Relationships | |
| Attached Files | out_displaced.e (4,156) 2012-04-10 10:47 https://www.vtk.org/Bug/file/9151/out_displaced.e |
| Issue History |
| 2012-04-10 10:47 | Utkarsh Ayachit | New Issue | |
| 2012-04-10 10:47 | Utkarsh Ayachit | File Added: out_displaced.e | |
| 2012-04-10 10:53 | Utkarsh Ayachit | Note Added: 0028441 | |
| 2012-05-25 13:14 | Utkarsh Ayachit | Assigned To | => Sebastiennn Jourdain |
| 2012-06-18 09:39 | Sebastien Jourdain | Note Added: 0028701 | |
| 2012-06-18 14:08 | Sebastien Jourdain | Status | backlog => todo |
| 2012-06-18 14:09 | Sebastien Jourdain | Status | todo => active development |
| 2012-07-18 18:00 | Sebastien Jourdain | Topic Name | => 13072-plot-over-line-on-1D-ds |
| 2012-07-18 18:00 | Sebastien Jourdain | Status | active development => gatekeeper review |
| 2012-07-18 18:00 | Sebastien Jourdain | Resolution | open => fixed |
| 2012-07-24 10:47 | Utkarsh Ayachit | Fixed in Version | => git-master |
| 2012-07-24 10:48 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2012-07-24 10:48 | Utkarsh Ayachit | Note Added: 0028896 | |
| 2012-07-25 20:20 | Alan Scott | Note Added: 0028945 | |
| 2012-07-25 20:20 | Alan Scott | Status | customer review => closed |
| 2012-10-29 17:04 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.0 |
(0028441)
Utkarsh Ayachit
2012-04-10 10:53
Probe filter it nor interpolating for points correctly, it seems. |
(0028701)
Sebastien Jourdain
2012-06-18 09:39
This is true for multi-block dataset. In fact, if you take each block on its own, that work just fine. Although the sample file seems to have a bunch of NaN values for each fields |
(0028896)
Utkarsh Ayachit
2012-07-24 10:48
merged into master, if applicable. |
(0028945)
Alan Scott
2012-07-25 20:20
Tested local server, Linux, master. |
