MantisBT - ParaView
View Issue Details
0013113ParaView(No Category)public2012-04-20 08:582016-08-12 09:59
Takuya OSHIMA
Utkarsh Ayachit
normalminorhave not tried
closedmoved
3.14.1
Kitware
crash
0013113: PV crashes with little endian client / big endian server setup
I get crashes with the following little endian client / big endian server setup:
Client:
Mac OS X 10.6.8 (Intel)
PV 3.14.1 OS X 64-bit binary downloaded from Kitware
Server:
Fujitsu FX10 (SPARC64 IXfx)
PV 3.14.1 cross-compiled on x86-64 Linux with CMake 2.8.7, FCCpx compiler
Server error messages:
mpiexec ~/fx/20120415/bin/pvserver --use-offscreen-rendering
Waiting for client...
Connection URL: cs://xxxxx:11111
Accepting connection(s): xxxxx:11111
Client connected.
[xxxxx:12678] *** Process received signal ***
[xxxxx:12678] Signal: Bus error (10)
[xxxxx:12678] Signal code: Invalid address alignment (1)
[xxxxx:12678] Failing at address: 0x214037b1
[xxxxx:12678] [ 0] /opt/FJSVxosmmm/lib64/libmpgpthread.so.1(_IO_funlockfile+0x5c) [0xffffffff20809974]
[xxxxx:12678] [ 1] /xxxxx/fx/20120415/lib/paraview-3.14/libvtkParallel.so.pv3.14(_ZN21vtkMultiProcessStream12vtkInternals9SwapBytesEv+0x1e4) [0xffffffff06783b64]
[xxxxx:12678] [ 2] /xxxxx/fx/20120415/lib/paraview-3.14/libvtkParallel.so.pv3.14(_ZN21vtkMultiProcessStream10SetRawDataEPKhj+0x440) [0xffffffff06778b80]
[xxxxx:12678] [ 3] /xxxxx/fx/20120415/lib/paraview-3.14/libvtkPVServerImplementation.so(_ZN18vtkPVSessionServer24OnClientServerMessageRMIEPvi+0x18) [0xffffffff008aec98]
[xxxxx:12678] [ 4] /xxxxx/fx/20120415/lib/paraview-3.14/libvtkPVServerImplementation.so(_ZN46_GLOBAL__N__22_vtkPVSessionServer_cxx_cc8ff48111RMICallbackEPvS0_ii+0xc) [0xffffffff008ac5cc]
[xxxxx:12678] [ 5] /xxxxx/fx/20120415/lib/paraview-3.14/libvtkParallel.so.pv3.14(_ZN25vtkMultiProcessController10ProcessRMIEiPvii+0x3f0) [0xffffffff0676c8b0]
[xxxxx:12678] [ 6] /xxxxx/fx/20120415/lib/paraview-3.14/libvtkParallel.so.pv3.14(_ZN25vtkMultiProcessController11ProcessRMIsEii+0x210) [0xffffffff0676bfd0]
[xxxxx:12678] [ 7] /xxxxx/fx/20120415/lib/paraview-3.14/libvtkPVClientServerCore.so(_ZN26vtkTCPNetworkAccessManager21ProcessEventsInternalEmb+0x3c4) [0xffffffff01116f44]
[xxxxx:12678] [ 8] /xxxxx/fx/20120415/lib/paraview-3.14/libvtkPVClientServerCore.so(_ZN26vtkTCPNetworkAccessManager13ProcessEventsEm+0xc) [0xffffffff01116b4c]
[xxxxx:12678] [ 9] /xxxxx/fx/20120415/lib/paraview-3.14/pvserver [0x102440]
[xxxxx:12678] [10] /xxxxx/fx/20120415/lib/paraview-3.14/pvserver(main+0xc) [0x10250c]
[xxxxx:12678] [11] /lib64/libc.so.6(__libc_start_main+0x194) [0xffffffff2118b81c]
[xxxxx:12678] [12] /xxxxx/fx/20120415/lib/paraview-3.14/pvserver(_start+0x2c) [0x10206c]
[xxxxx:12678] *** End of error message ***
[ERR.] PLE 0017 plexec The process terminated with the signal.(rank=0)(nid=0x01040006)(sig=10)
Client error messages:
> /Applications/ParaView\ 3.14.1.app/Contents/MacOS/paraview
ERROR: In /Source/ParaView/release/ParaView/VTK/Parallel/vtkSocketCommunicator.cxx, line 812
vtkSocketCommunicator (0x10d88b820): Could not receive tag. 55627
ERROR: In /Source/ParaView/release/ParaView/ParaViewCore/ServerManager/vtkSMSessionClient.cxx, line 774
vtkSMSessionClient (0x10c6bc1f0): Server failed to gather information.
vtkSocketCommunicator (0x10d88b820): Could not receive tag. 55629
vtkSocketCommunicator (0x10d88b820): Could not receive tag. 55628
libprotobuf ERROR /Source/ParaView/release/ParaView/Utilities/protobuf/src/google/protobuf/message_lite.cc:123] Can't parse message of type "paraview_protobuf.Message" because it is missing required fields: global_id, location
ERROR: In /Source/ParaView/release/ParaView/ParaViewCore/ServerManager/vtkSMProxy.cxx, line 1874
vtkSMPluginLoaderProxy (0x11be90290): Try to load a state on a proxy which has a different ID(1 != 0)
No tags attached.
Issue History
2012-04-20 08:58Takuya OSHIMANew Issue
2012-04-20 09:06Utkarsh AyachitAssigned To => Utkarsh Ayachit
2016-08-12 09:59Kitware RobotNote Added: 0038197
2016-08-12 09:59Kitware RobotStatusbacklog => closed
2016-08-12 09:59Kitware RobotResolutionopen => moved
Notes
(0038197)
Kitware Robot
2016-08-12 09:59
Resolving issue as `moved`.
