MantisBT - ParaView
View Issue Details
0013150ParaView(No Category)public2012-05-04 09:292012-10-29 17:04
Utkarsh Ayachit
Utkarsh Ayachit
normalminorhave not tried
closedfixed
3.98.0
Sandia
13150-add-simpler-ui-for-findData
feature
0013150: Simplify "Find Data" dialog
Simplify "Find Data" dialog. User's are finding it hard to write expressions.
No tags attached.
related to 0013225closed Sebastien Jourdain Crash Bug/Bad Memory Read in pqQueryDialog (vtkDataObjectTypes::GetClassNameFromTypeId also partly to blame)
related to 0010955closed Alan Scott Find/Edit data command - turn text on/off
related to 0010958closed Utkarsh Ayachit Edit/Find data command - find and calculate min and max variable for each time step of an animation
related to 0010956closed Utkarsh Ayachit Find/Edit data command - ability to click on a cell or point, highlighted on
Issue History
2012-05-04 09:29Utkarsh AyachitNew Issue
2012-05-04 09:29Utkarsh AyachitAssigned To => Utkarsh Ayachit
2012-05-04 09:33Utkarsh AyachitAssigned ToUtkarsh Ayachit => Kyle Lutz
2012-05-22 19:26Alan ScottRelationship addedrelated to 0010955
2012-05-22 19:27Alan ScottRelationship addedrelated to 0010958
2012-05-22 19:28Alan ScottRelationship addedrelated to 0010956
2012-05-31 10:23Utkarsh AyachitStatusbacklog => todo
2012-06-19 16:35Utkarsh AyachitAssigned ToKyle Lutz => Sebastiennn Jourdain
2012-06-20 10:58Utkarsh AyachitRelationship addedrelated to 0013225
2012-07-18 11:21Sebastien JourdainStatustodo => active development
2012-07-25 18:53Sebastien JourdainTopic Name => 13150-add.... don't remember....
2012-07-25 18:53Sebastien JourdainStatusactive development => gatekeeper review
2012-07-25 18:53Sebastien JourdainResolutionopen => fixed
2012-07-27 14:42Utkarsh AyachitFixed in Version => git-master
2012-07-27 14:43Utkarsh AyachitStatusgatekeeper review => customer review
2012-07-27 14:43Utkarsh AyachitNote Added: 0028956
2012-08-01 17:38Sebastien JourdainStatuscustomer review => active development
2012-08-01 17:39Sebastien JourdainTopic Name13150-add.... don't remember.... => 13150-add-simpler-ui-for-findData
2012-08-01 17:39Sebastien JourdainStatusactive development => gatekeeper review
2012-08-07 14:28Utkarsh AyachitNote Added: 0028974
2012-08-07 14:33Sebastien JourdainNote Added: 0028975
2012-08-10 15:49Sebastien JourdainAssigned ToSebastien Jourdain => Utkarsh Ayachit
2012-08-10 15:49Sebastien JourdainNote Added: 0028996
2012-08-17 14:27Utkarsh AyachitStatusgatekeeper review => customer review
2012-08-17 14:27Utkarsh AyachitNote Added: 0029018
2012-09-20 17:19Alan ScottNote Added: 0029242
2012-09-20 17:19Alan ScottStatuscustomer review => closed
2012-10-29 17:04Utkarsh AyachitFixed in Versiongit-master => 3.98.0
Notes
(0028956)
Utkarsh Ayachit
2012-07-27 14:43
merged into master, if applicable.
(0028974)
Utkarsh Ayachit
2012-08-07 14:28
(Seb, can you add a screen shot or some explaination for what this task did and how to test it? Thanks).
(0028975)
Sebastien Jourdain
2012-08-07 14:33
This should bring back the old FindDialog option with the list of fields in the combobox instead of having only the "Query" choice.
Moreover, after executing the findData, if you switch to query, you can see what your setup match to the query syntax.
(0028996)
Sebastien Jourdain
2012-08-10 15:49
Seems to be properly in Master now...
(0029018)
Utkarsh Ayachit
2012-08-17 14:27
merged in master, if applicable
(0029242)
Alan Scott
2012-09-20 17:19
Interface has been simplified. Still need other features, such as min and max.
