MantisBT - ParaView | |||||
| View Issue Details | |||||
| 0013386 | ParaView | (No Category) | public | 2012-08-22 21:04 | 2012-10-29 17:04 |
| Reporter | Alan Scott | ||||
| Assigned To | Utkarsh Ayachit | ||||
| Priority | high | Severity | minor | Reproducibility | have not tried |
| Status | closed | Resolution | fixed | ||
| Product Version | git-master | ||||
| Target Version | Fixed in Version | 3.98.0 | |||
| Project | Sandia | ||||
| Topic Name | 13386_fix_cth_derived_quantities | ||||
| Type | incorrect functionality | ||||
| Summary | 0013386: Failure reading CTH files - Compute Derived Variables | ||||
| Description | I have a CTH dataset that is failing on read. Windows (Linux also fails), local server, master. Open dataset. All vars on. Apply. Error print is as follows: ERROR: In ..\..\..\..\..\src\ParaView3\VTK\Common\DataModel\vtkDataSet.cxx, line 437 vtkRectilinearGrid (189FF048): Cell array Derived Density - 1 with 1 components, has only 0 tuples but there are 74884 cells The error is here: file: vtkDataSet.cxx, line 437. The cause of the error message is as follows: array name == Derived Density - 1 number of tuples == 0 number of cells = 74884 We are failing on an if test making sure that the number of tuples == number of cells. Workaround - in the reader, before clicking "Apply", deselect "Compute Derived Variables". This is a show stopper for 4.0. I will give Utkarsh the dataset. It is named flat_2d-crash-snl-do-not-release.tar.gz | ||||
| Steps To Reproduce | |||||
| Relationships | |||||
| Attached Files | |||||
| Issue History | |||||
| 2012-08-22 21:04 | Alan Scott | New Issue | |||
| 2012-08-22 21:05 | Alan Scott | Note Added: 0029048 | |||
| 2012-08-22 21:05 | Alan Scott | Assigned To | => Alan Scott | ||
| 2012-08-22 21:05 | Alan Scott | Status | backlog => todo | ||
| 2012-09-05 18:23 | Utkarsh Ayachit | Topic Name | => 13386_fix_cth_derived_quantities | ||
| 2012-09-05 18:23 | Utkarsh Ayachit | Note Added: 0029133 | |||
| 2012-09-05 18:23 | Utkarsh Ayachit | Status | todo => gatekeeper review | ||
| 2012-09-05 18:23 | Utkarsh Ayachit | Fixed in Version | => git-next | ||
| 2012-09-05 18:23 | Utkarsh Ayachit | Resolution | open => fixed | ||
| 2012-09-05 18:23 | Utkarsh Ayachit | Assigned To | Alan Scott => Utkarsh Ayachit | ||
| 2012-09-07 14:50 | Utkarsh Ayachit | Fixed in Version | git-next => git-master | ||
| 2012-09-07 14:50 | Utkarsh Ayachit | Status | gatekeeper review => customer review | ||
| 2012-09-07 14:50 | Utkarsh Ayachit | Note Added: 0029143 | |||
| 2012-09-19 19:46 | Alan Scott | Note Added: 0029225 | |||
| 2012-09-19 19:46 | Alan Scott | Status | customer review => closed | ||
| 2012-10-29 17:04 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.0 | ||
| Notes | |||||
