MantisBT - ParaView | |||||
View Issue Details | |||||
0013583 | ParaView | (No Category) | public | 2012-10-29 08:10 | 2012-11-14 16:32 |
Reporter | Felipe Bordeu | ||||
Assigned To | Sebastien Jourdain | ||||
Status | closed | Resolution | fixed | ||
Product Version | 3.14.1 | ||||
Project | TBD | ||||
Topic Name | |||||
Summary | 0013583: Transform does not change the label data | ||||
Description | When a ShearedCube (plugin) is created with: Use Base : enabled Use Custom Range :enabled and the a transform filter is applied with rotation, scale, translation. The cube Axes information is not transform. to recreate this bug : load plugin NonOrthogonalsource. Sources -> ShearedCube enable "Use Base" and "Use Custom Range" Apply Transform filter (with any rotation/translation/scale) In the Display tab, enable CubeAxes Visible Felipe | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | ![]() https://www.vtk.org/Bug/file/9322/CustomCubeAxesTransformBug.png ![]() | ||||
Issue History | |||||
2012-10-29 08:10 | Felipe Bordeu | New Issue | |||
2012-10-29 08:10 | Felipe Bordeu | File Added: CustomCubeAxesTransformBug.png | |||
2012-11-14 16:32 | Sebastien Jourdain | Note Added: 0029718 | |||
2012-11-14 16:32 | Sebastien Jourdain | Status | backlog => closed | ||
2012-11-14 16:32 | Sebastien Jourdain | Assigned To | => Sebastien Jourdain | ||
2012-11-14 16:32 | Sebastien Jourdain | Resolution | open => fixed |
Notes | |||||
