MantisBT - ParaView
View Issue Details
0013596ParaView(No Category)public2012-10-31 20:282016-08-12 09:59
Alan Scott
David Thompson
normalminorhave not tried
closedmoved
git-master
Sandia
incorrect functionality
0013596: Zoom to box does not zoom correctly.
Linux, remote server, master.
sources/ sphere. Apply.
Zoom to box, upper left side of the sphere. Be sure to have some of the zoom inside and outside of the sphere.
<<Bug - the screen will only show the sphere>>
This was noticed by a user, thus should be fixed.
No tags attached.
Issue History
2012-10-31 20:28Alan ScottNew Issue
2012-12-11 09:53Sebastien JourdainAssigned To => David Thompson
2015-07-05 09:15Cory QuammenNote Added: 0034662
2016-08-12 09:59Kitware RobotNote Added: 0038269
2016-08-12 09:59Kitware RobotStatusbacklog => closed
2016-08-12 09:59Kitware RobotResolutionopen => moved
Notes
(0034662)
Cory Quammen
2015-07-05 09:15
Alan,
I suspect this has to do with the inherent difficulty in using a 2D rectangle to specify a zoom region with perspective projection of a 3D scene. Try turning on the "Camera Parallel Projection" setting under the View section of the properties panel. Since this turns off perspective projection, the mapping from the rectangle to zoomed view is easier and seems to work better.
(0038269)
Kitware Robot
2016-08-12 09:59
Resolving issue as `moved`.
