MantisBT - ParaView
View Issue Details
0013632ParaView(No Category)public2012-11-08 11:182012-11-08 11:41
Joe Borg
normalminorhave not tried
closedno change required
3.98.0
TBD
incorrect functionality
0013632: Large geometry representation being set to surface instead of outline by default
In ParaView 3.14, if you load a large dataset, the representation would automatically be set to "Outline". If the dataset was smaller, or you use ExtractBlock to get the size down, ParaView selects "Surface" by default. In 3.98 however, everything is set to "Surface", so if you load a dataset with a huge flow field, it takes ages to load or crashes.
No tags attached.
Issue History
2012-11-08 11:18Joe BorgNew Issue
2012-11-08 11:41Joe BorgNote Added: 0029673
2012-11-08 11:41Joe BorgStatusbacklog => closed
2012-11-08 11:41Joe BorgResolutionopen => no change required
2012-11-08 11:41Joe BorgFixed in Version => 3.98.0
Notes
(0029673)
Joe Borg
2012-11-08 11:41
I have found this setting. It's under "Edit" > "Settings..." > "Render View" > "Default Representation".
