MantisBT - ParaView | |||||
View Issue Details | |||||
0013656 | ParaView | (No Category) | public | 2012-11-13 18:13 | 2016-08-12 09:59 |
Reporter | Orion Poplawski | ||||
Product Version | |||||
Project | TBD | ||||
Topic Name | |||||
Type | feature | ||||
Summary | 0013656: Try to support using system installed protobuf | ||||
Description | For Fedora packages, need to use the system installed version of libraries. Attached is a hack to try to do that with 3.98.0. First step is to change: -vtk_module_third_party(protobuf +vtk_module_third_party(Protobuf in ParaView/ThirdParty/protobuf/CMakeLists.txt so that cmake finds FindProtobuf.cmake. Next I hacked out: +#vtk_target_export(protobuf) +#vtk_target_export(protobuf-lite) +#vtk_compile_tools_target_export(protoc_compiler) because they are not available in that configuration. Finally, Fedora 18 has protobuf 2.4.1 and the compiler is named "protoc" so I changed the name in ParaView/ParaViewCore/ServerImplementation/Core/CMakeLists.txt and removed protoc_compiler as a build dependency. Finally though I get the following link error: /usr/lib64/ccache/g++ -fPIC -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic -g -Wl,--fatal-warnings -Wl,--no-undefined -lc -Wl,-z,relro -shared -Wl,-soname,libvtkPVServerImplementationCore-pv3.98.so.1 -o ../../../lib/libvtkPVServerImplementationCore-pv3.98.so.1 CMakeFiles/vtkPVServerImplementationCore.dir/vtkPVCatalystSessionCore.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkPVProxyDefinitionIterator.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkPVSessionBase.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkPVSessionCore.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkPVSessionCoreInterpreterHelper.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkPVSessionServer.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSIArraySelectionProperty.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSICollaborationManager.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSICompoundSourceProxy.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSIDataArrayProperty.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSIDoubleVectorProperty.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSIFileSeriesReaderProxy.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSIIdTypeVectorProperty.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSIInputProperty.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSIIntVectorProperty.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSIObject.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSIProperty.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSIProxy.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSIProxyDefinitionManager.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSIProxyProperty.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSISILProperty.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSISourceProxy.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSIStringVectorProperty.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSITimeLabelProperty.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSITimeRangeProperty.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSITimeStepsProperty.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSIVectorProperty.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSIWriterProxy.cxx.o CMakeFiles/vtkPVServerImplementationCore.dir/vtkSMMessage.cxx.o ../../../lib/libvtkPVClientServerCoreCore-pv3.98.so.1 -lprotobuf ../../../lib/libvtkFiltersProgrammable-pv3.98.so.1 ../../../lib/libvtkPVPythonSupport-pv3.98.so.1 -lpython2.7 ../../../lib/libvtkPVVTKExtensionsCore-pv3.98.so.1 ../../../lib/libvtkPVCommon-pv3.98.so.1 ../../../lib/libvtkClientServer-pv3.98.so.1 ../../../lib/libvtkIOXML-pv3.98.so.1 ../../../lib/libvtkIOGeometry-pv3.98.so.1 ../../../lib/libvtkIOXMLParser-pv3.98.so.1 -lexpat ../../../lib/libvtkImagingCore-pv3.98.so.1 ../../../lib/libvtkInfovisCore-pv3.98.so.1 ../../../lib/libvtkFiltersExtraction-pv3.98.so.1 ../../../lib/libvtkFiltersGeneral-pv3.98.so.1 ../../../lib/libvtkFiltersCore-pv3.98.so.1 ../../../lib/libvtkCommonComputationalGeometry-pv3.98.so.1 ../../../lib/libvtkParallelCore-pv3.98.so.1 ../../../lib/libvtkIOLegacy-pv3.98.so.1 ../../../lib/libvtkIOCore-pv3.98.so.1 ../../../lib/libvtkCommonExecutionModel-pv3.98.so.1 ../../../lib/libvtkCommonDataModel-pv3.98.so.1 ../../../lib/libvtkCommonSystem-pv3.98.so.1 ../../../lib/libvtkCommonTransforms-pv3.98.so.1 ../../../lib/libvtkCommonMisc-pv3.98.so.1 ../../../lib/libvtkCommonMath-pv3.98.so.1 ../../../lib/libvtkCommonCore-pv3.98.so.1 ../../../lib/libvtksys-pv3.98.so.1 -ldl -lz -Wl,-rpath,/export/home/orion/fedora/paraview/ParaView/fedora/lib: CMakeFiles/vtkPVServerImplementationCore.dir/vtkSMMessage.cxx.o: In function `protobuf_AssignDescriptorsOnce': CMakeFiles/vtkPVServerImplementationCore.dir/vtkSMMessage.cxx.o:/usr/include/google/protobuf/stubs/once.h:115: more undefined references to `pthread_once' follow It's going to need to link against -lpthread but I don't know the best way to handle that. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | ![]() https://www.vtk.org/Bug/file/9340/paraview-Protobuf.patch ![]() https://www.vtk.org/Bug/file/9489/paraview-4.0.1-Protobuf.patch ![]() https://www.vtk.org/Bug/file/9705/paraview-4.2RC1-Protobuf.patch ![]() https://www.vtk.org/Bug/file/9707/paraview-cmake.patch | ||||
Issue History | |||||
2012-11-13 18:13 | Orion Poplawski | New Issue | |||
2012-11-13 18:13 | Orion Poplawski | File Added: paraview-Protobuf.patch | |||
2013-07-29 10:59 | hasufell | File Added: paraview-4.0.1-Protobuf.patch | |||
2013-07-29 10:59 | hasufell | Note Added: 0031359 | |||
2013-07-29 17:07 | Orion Poplawski | Note Added: 0031363 | |||
2014-09-03 14:10 | Orion Poplawski | Note Added: 0033306 | |||
2014-09-03 18:39 | Orion Poplawski | File Added: paraview-4.2RC1-Protobuf.patch | |||
2014-09-03 18:41 | Orion Poplawski | Note Added: 0033307 | |||
2014-09-04 12:33 | Orion Poplawski | Note Added: 0033309 | |||
2014-09-05 11:33 | Orion Poplawski | File Added: paraview-cmake.patch | |||
2014-09-05 12:06 | Orion Poplawski | Note Added: 0033312 | |||
2015-04-30 11:52 | Orion Poplawski | Note Added: 0034391 | |||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038279 | |||
Notes | |||||
