MantisBT - VTK | |||||
View Issue Details | |||||
0013707 | VTK | (No Category) | public | 2012-12-06 08:57 | 2014-10-02 10:45 |
Reporter | Giuseppe D'Angelo | ||||
Assigned To | Marcus D. Hanwell | ||||
Status | closed | Resolution | fixed | ||
Product Version | 5.8.0 | ||||
Project | TBD | ||||
Summary | 0013707: vtkXOpenGLRenderWindow doesn't properly reset to the default cursor | ||||
Description | VTK 5.10.1, in vtkXOpenGLRenderWindow.cxx: 1985 if (shape == VTK_CURSOR_DEFAULT) 1986 { 1987 XUndefineCursor(this->DisplayId,this->WindowId); 1988 return; 1989 } I think this is wrong. This should reset the cursor to the one was set with SetCurrentCursor. Doing so will just switch to the parent's cursor instead. As a test, set a non-arrow cursor with SetCurrentCursor, then add a widget which changes the mouse cursor (f.i. a vtkScalarBarWidget). When moving the mouse outside the widget, it'll reset the cursor to a plain arrow. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2012-12-06 08:57 | Giuseppe D'Angelo | New Issue | |||
2013-06-25 13:48 | Dave DeMarle | Note Added: 0031058 | |||
2014-10-02 10:10 | Berk Geveci | Assigned To | => Marcus D. Hanwell | ||
2014-10-02 10:23 | Marcus D. Hanwell | Note Added: 0033437 | |||
2014-10-02 10:23 | Marcus D. Hanwell | Status | backlog => active development | ||
2014-10-02 10:44 | Marcus D. Hanwell | Note Added: 0033446 | |||
2014-10-02 10:44 | Marcus D. Hanwell | Status | active development => backlog | ||
2014-10-02 10:45 | Marcus D. Hanwell | Note Added: 0033447 | |||
2014-10-02 10:45 | Marcus D. Hanwell | Status | backlog => closed | ||
2014-10-02 10:45 | Marcus D. Hanwell | Resolution | open => fixed |
Notes | |||||
