MantisBT - ParaView
View Issue Details
0013799ParaView(No Category)public2013-01-17 12:522015-01-11 08:28
Alan Scott
Utkarsh Ayachit
normalminorhave not tried
closedfixed
git-master
3.98.1
Sandia
13799_comparative_view_fixes
incorrect functionality
0013799: Comparitive view doesn't show variables correctly.
Linux, master, local server.
Wavelet. Apply. Notice that the outline view is shown.
Right click on the title bar for the 3d window. Convert to 3d View Comparative.
Turn on visibility for Wavelet (this is a bug in another bug report).
Change Representation to Surface.
Try changing Solid Color to RTData. This variable doesn't show up. This is a bug.
The way to show that it should is to split the screen, and display wavelet in a 3d window. If you then select the comparative view, RTData will show up as a color option.
No tags attached.
has duplicate 0013800closed Utkarsh Ayachit Comparitive view inspector doesn't work
Issue History
2013-01-17 12:52Alan ScottNew Issue
2013-01-22 10:03Utkarsh AyachitRelationship addedrelated to 0013800
2013-01-22 11:57Utkarsh AyachitRelationship replacedhas duplicate 0013800
2013-01-22 12:00Utkarsh AyachitTopic Name => 13799_comparative_view_fixes
2013-01-22 12:33Utkarsh AyachitNote Added: 0030207
2013-01-22 12:33Utkarsh AyachitStatusbacklog => gatekeeper review
2013-01-22 12:33Utkarsh AyachitFixed in Version => git-next
2013-01-22 12:33Utkarsh AyachitResolutionopen => fixed
2013-01-22 12:33Utkarsh AyachitAssigned To => Utkarsh Ayachit
2013-01-26 10:27Utkarsh AyachitFixed in Versiongit-next => git-master
2013-01-26 10:27Utkarsh AyachitStatusgatekeeper review => customer review
2013-01-26 10:27Utkarsh AyachitNote Added: 0030257
2013-01-30 10:40Utkarsh AyachitFixed in Versiongit-master => 3.98.1
2013-02-11 19:26Alan ScottNote Added: 0030331
2013-02-11 19:26Alan ScottStatuscustomer review => closed
2015-01-11 08:28Utkarsh AyachitSource_changeset_attached => ParaView master 274e1691
2015-01-11 08:28Utkarsh AyachitSource_changeset_attached => ParaView master 8586b702
2015-01-11 08:28Utkarsh AyachitSource_changeset_attached => ParaView master 530dc146
2015-01-11 08:28Utkarsh AyachitSource_changeset_attached => ParaView master 70f9e297
Notes
(0030207)
Utkarsh Ayachit
2013-01-22 12:33
commit 87e901648e8eeed54573ba2a4e32b717ab0cfe0d
Date: Tue Jan 22 12:18:36 2013 -0500
    Fixed Overlay mode in Comparative View.
    When in Overlay mode, all representations were simply showing the first
    timestep. This is because when the view was updated for (0, 0), it would update
    all representations in it, including those for other locations in the
    comparative grid. The caches for all those representations would be filled and
    subsequence updates would have no effect. This addresses that issue by clearing
    caches for representations at (i, j) location just before updating the
    representations at (i, j) location.
    Added a test for the same (ComparativeOverlay).
    Change-Id: I05493e4258e54a7dc9b4554c56f40f8271e22f21
commit 70f9e297b00ccb852dbb9bedaa65d3d83c9937fe
Date: Tue Jan 22 11:57:59 2013 -0500
    BUG 0013799. Variables not showing curretly for Comparative View.
    The problem was that the representations in each view were being updated using
    repr->Update() instead of simply letting the view update the representations as
    needed. Since vtkCompositeRepresentation::Update() no longer forwards the update
    request to internal representations, it meant that the UI ended up updating
    using old state of the representations -- hence the missing variables. This
    fixes that issue.
    Change-Id: Ia25e7dd8f4d5c0c368692894003567eb8bf79043
(0030257)
Utkarsh Ayachit
2013-01-26 10:27
SUMMARY
Topics merged into master:
        0013365-huge-state-file
(VTK) 0013470-CTH-AMR-OutlineFilter
        13311_fix_time_marker
        13784_cleanup_chart_settings_dialog
        13811_fix_3Dwidgets
(VTK) 13817_fix_memory_issues
        13818_fix_plot_min_max
(VTK) 13821_fix_leaks_on_exit
        13824_fix_calculator
        PvxFullScreenBorders
        vr-fixInteractors
        vr-missingIncludes
(0030331)
Alan Scott
2013-02-11 19:26
Tested 3.98.1, local server, Linux.
