MantisBT - ParaView
View Issue Details
0013831ParaView(No Category)public2013-01-29 17:492016-08-12 09:59
Alan Scott
Kitware Robot
normalminorhave not tried
closedmoved
git-master
Sandia
incorrect functionality
0013831: Master bug - Progress Handler is a mess
This is a master bug that I will hang sub bugs off of. Basically, the current Progress Handler is a mess. This bug relates to file vtkPVProgressHandler.cxx, plus imbedded code in all of the filters that calls it. I am seeing the following:
* No parameter checking for bad input variables. (progress should generally be 0.0 to 1.0 within the code)
* No print statements in the Progress Handler that can be turned on that shows that progress actually increments.
* Intermixing progress of a range of 0.0 to 1.0 and 0.0 to 100.0 within the same object/functions. This is undocumented, and very confusing.
* Progress coming into the Progress Handler from filters (expected progress of 0.0-1.0) with a range up to 10's or 100's (1000% to 10000% done).
* Some conditions (such as a status of 0.0, or any number out of the 0-1 range) that is flooding MPI with messages.
* Some filters, such as the CTH reader, that runs absolutely crazy progress. For instance, with the CTH reader, status is 0.0 to 0.2, then backs up and runs 0.04 to 0.38, then 0.64 to 1.0.
* Running multiple server sometimes provides crazy results (see ranges outside of 0.0-1.0 above).
That's probably a good start. I will post additional bug reports with specifics.
No tags attached.
parent of 0013832closed Kitware Robot ProgressHandler - Cell to Point is broken
parent of 0013833closed Kitware Robot ProgressHandler - spyPlotReader is broken
parent of 0013835closed Kitware Robot ProgressHandler -Exodus Reader is broken
parent of 0013834closed Kitware Robot ProgressHandler needs fixing, error checking, consistency and COMMENTS.
parent of 0013836closed Kitware Robot ProgressHandler - Most filters - are broken
parent of 0013839closed Utkarsh Ayachit Progress status locks multiserver
Issue History
2013-01-29 17:49Alan ScottNew Issue
2013-01-29 17:51Alan ScottDescription Updatedbug_revision_view_page.php?rev_id=553#r553
2013-01-29 21:48Alan ScottRelationship addedparent of 0013832
2013-01-29 21:49Alan ScottRelationship addedparent of 0013833
2013-01-29 21:49Alan ScottRelationship addedparent of 0013835
2013-01-29 21:50Alan ScottRelationship addedparent of 0013834
2013-01-29 21:50Alan ScottRelationship addedparent of 0013836
2013-01-30 16:34Alan ScottRelationship addedparent of 0013839
2013-05-01 15:58Nikhil ShettyAssigned To => Nikhil Shetty
2013-05-01 16:12Nikhil ShettyNote Added: 0030671
2013-05-01 16:12Nikhil ShettyStatusbacklog => todo
2013-06-05 16:01Nikhil ShettyAssigned ToNikhil Shetty =>
2015-01-11 08:27Utkarsh AyachitSource_changeset_attached => ParaView master e1f6e4e5
2015-01-11 08:28Utkarsh AyachitSource_changeset_attached => ParaView master 6242d9a0
2016-08-12 09:59Kitware RobotNote Added: 0038322
2016-08-12 09:59Kitware RobotStatustodo => closed
2016-08-12 09:59Kitware RobotResolutionopen => moved
2016-08-12 09:59Kitware RobotAssigned To => Kitware Robot
Notes
(0030671)
Nikhil Shetty
2013-05-01 16:12
One of issue may be a general issue for multiblock data sets. The CompositeDataPipeline executes one algorithm for every block. During each run the algorithm reports progress from 0.0 - 1.0 and thus we see multiple progress for a single run.
The GUI takes range from 0.0 to 100 and so there may be some things arising out of this confusion.
Fixes are on their way.
(0038322)
Kitware Robot
2016-08-12 09:59
Resolving issue as `moved`.
