MantisBT - ParaView |
View Issue Details |
0013832 | ParaView | (No Category) | public | 2013-01-29 18:22 | 2016-08-12 09:59 |
Reporter | Alan Scott | |
Assigned To | Kitware Robot | |
Status | closed | Resolution | moved | |
Product Version | git-master | |
Target Version | | Fixed in Version | | |
Project | Sandia |
Topic Name | 0013832-Fix-ProgressHandler-CellToPoint |
Type | incorrect functionality |
Summary | 0013832: ProgressHandler - Cell to Point is broken |
Description | Progress handler code in Cell to Point is broken. In file vtkCellDataToPointData.cxx, function vtkCellDataToPointData::RequestData(), update progress gets called many dozens of times (speculation is once per block, which could be millions of times). Each time this code dutifully bounces the UpdateProgress(progress) call from 0.0 to 1.0, in increments of 0.05. I am not even going to try a fix.
Suggested hack would be to comment out the UpdateProgress.
vtkCellDataToPointData.cxx, line 106, should change from:
this->UpdateProgress(static_cast<double>(ptId)/numPts);
to
//this->UpdateProgress(static_cast<double>(ptId)/numPts);
Steps To Reproduce | |
Additional Information | |
Tags | No tags attached. |
Relationships | child of | 0013831 | closed | Kitware Robot | Master bug - Progress Handler is a mess |
Attached Files | |
2013-01-29 18:22 | Alan Scott | New Issue | |
2013-01-29 21:48 | Alan Scott | Relationship added | child of 0013831 |
2013-02-06 18:34 | Utkarsh Ayachit | Assigned To | => Nikhil Shetty |
2013-02-06 18:35 | Utkarsh Ayachit | Note Added: 0030316 | |
2013-02-19 10:22 | Nikhil Shetty | Status | backlog => todo |
2013-02-20 11:59 | Nikhil Shetty | Topic Name | => 0013832-Fix-ProgressHandler-CellToPoint |
2013-02-20 11:59 | Nikhil Shetty | Status | todo => active development |
2013-06-05 16:33 | Nikhil Shetty | Assigned To | Nikhil Shetty => |
2013-06-05 16:34 | Nikhil Shetty | Status | active development => todo |
2013-06-05 16:41 | Nikhil Shetty | Status | todo => backlog |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038323 | |
