MantisBT - VTK | ||||||||||||||||||||
View Issue Details | ||||||||||||||||||||
ID | Project | Category | View Status | Date Submitted | Last Update | |||||||||||||||
0013860 | VTK | (No Category) | public | 2013-02-04 06:26 | 2014-10-02 11:03 | |||||||||||||||
Reporter | Massimiliano Martinelli | |||||||||||||||||||
Assigned To | Chuck Atkins | |||||||||||||||||||
Priority | normal | Severity | minor | Reproducibility | have not tried | |||||||||||||||
Status | closed | Resolution | unable to reproduce | |||||||||||||||||
Platform | OS | OS Version | ||||||||||||||||||
Product Version | 5.10.1 | |||||||||||||||||||
Target Version | Fixed in Version | 6.2.0 | ||||||||||||||||||
Project | Kitware | |||||||||||||||||||
Type | crash | |||||||||||||||||||
Summary | 0013860: the vtkXMLUnstructuredGridWriter crashes on MacOSX 10.6.8 | |||||||||||||||||||
Description | When I run the code in attachment on a MacOSX 10.6.8 the program crashes with the following message: vtk_writer.exe(6943) malloc: *** error for object 0x7fff70e33500: pointer being freed was not allocated *** set a breakpoint in malloc_error_break to debug Abort trap The function that is causing the problem seems to be vtkXMLUnstructuredGridWriter::Write(). The vtk library is compiled from the MacPorts tree. The same code works fine on linux. | |||||||||||||||||||
Steps To Reproduce | ||||||||||||||||||||
Additional Information | ||||||||||||||||||||
Tags | hackaton | |||||||||||||||||||
Attached Files | ![]() https://www.vtk.org/Bug/file/9393/vtk_writer.cpp | |||||||||||||||||||
Issue History | ||||||||||||||||||||
Date Modified | Username | Field | Change | |||||||||||||||||
2013-02-04 06:26 | Massimiliano Martinelli | New Issue | ||||||||||||||||||
2013-02-04 06:26 | Massimiliano Martinelli | File Added: vtk_writer.cpp | ||||||||||||||||||
2013-02-04 10:46 | Sean McBride | Note Added: 0030298 | ||||||||||||||||||
2013-06-25 14:22 | Dave DeMarle | Relationship added | related to 0013295 | |||||||||||||||||
2013-06-25 14:22 | Dave DeMarle | Relationship added | parent of 0013294 | |||||||||||||||||
2013-06-25 14:22 | Dave DeMarle | Relationship deleted | parent of 0013294 | |||||||||||||||||
2013-06-25 14:22 | Dave DeMarle | Relationship added | related to 0013294 | |||||||||||||||||
2013-06-25 14:23 | Dave DeMarle | Relationship added | related to 0013382 | |||||||||||||||||
2014-10-01 17:15 | Sean McBride | Assigned To | => Sean McBride | |||||||||||||||||
2014-10-01 17:15 | Sean McBride | Tag Attached: hackaton | ||||||||||||||||||
2014-10-02 09:41 | Chuck Atkins | Assigned To | Sean McBride => Chuck Atkins | |||||||||||||||||
2014-10-02 09:45 | Chuck Atkins | Status | backlog => active development | |||||||||||||||||
2014-10-02 11:03 | Chuck Atkins | Note Added: 0033457 | ||||||||||||||||||
2014-10-02 11:03 | Chuck Atkins | Status | active development => closed | |||||||||||||||||
2014-10-02 11:03 | Chuck Atkins | Resolution | open => unable to reproduce | |||||||||||||||||
2014-10-02 11:03 | Chuck Atkins | Fixed in Version | => 6.2.0 |
Notes | |||||
