MantisBT - ParaView
View Issue Details
0013885ParaView(No Category)public2013-02-17 13:452013-05-21 21:55
Burlen
Utkarsh Ayachit
normalminorhave not tried
closedno change required
3.98.1
3.98.1
TBD
incorrect functionality
0013885: histogram : need a way to change legend from "bin_values"
histogram : need a way to change legend from "bin_values" to something custom that matches the dataset being analyzed.
No tags attached.
Issue History
2013-02-17 13:45BurlenNew Issue
2013-02-22 15:22Utkarsh AyachitNote Added: 0030375
2013-02-22 15:22Utkarsh AyachitStatusbacklog => gatekeeper review
2013-02-22 15:22Utkarsh AyachitFixed in Version => 3.98.1
2013-02-22 15:22Utkarsh AyachitResolutionopen => no change required
2013-02-22 15:22Utkarsh AyachitAssigned To => Utkarsh Ayachit
2013-02-22 15:22Utkarsh AyachitStatusgatekeeper review => customer review
2013-02-22 15:49BurlenNote Added: 0030376
2013-02-22 15:59BurlenNote Edited: 0030376bug_revision_view_page.php?bugnote_id=30376#r561
2013-05-21 21:55Alan ScottNote Added: 0030823
2013-05-21 21:55Alan ScottStatuscustomer review => closed
Notes
(0030375)
Utkarsh Ayachit
2013-02-22 15:22
You can indeed do that.
On the Properties panel, in the table widget where one chooses the arrays to plot, try clicking on the "Legend Name" column for the selected item, it enters "edit" mode where you can change the Legend Name.
(0030376)
Burlen
2013-02-22 15:49
(edited on: 2013-02-22 15:59)
ah, now I see it. I'm happy, but have the following comment:
For what it's worth, I never would have found how to do this on my own since it's fairly non-standard. What's there basically amounts to *slow* double click to edit. because single click *doesn't* let you edit the legend text value unless the row is already selected. If you double click too fast then color chooser opens. Right click does nothing even when the row is selected. Would be more intuitive if the first click (when the row isn't selected) or even right click let you edit. Or I can get used to the current behavior ;-)
(0030823)
Alan Scott
2013-05-21 21:55
I am accepting Utkarsh's answer below.
Turns out that once the line is highlighted, a single click allows a user to edit this field. I believe this is standard most places in ParaView. Thus, closing.
Tested Linux, master.
