MantisBT - ParaView
View Issue Details
0013887ParaView(No Category)public2013-02-17 14:042013-05-21 21:50
Burlen
Kyle Lutz
normalminorhave not tried
closedfixed
3.98.1
TBD
13887-avoid-spurious-render
incorrect functionality
0013887: spurious render triggered from auto-generated line edits in display panel
[Paraview] auto generated line edits in the display panel
Utkarsh Ayachit utkarsh.ayachit at kitware.com
Sat Oct 20 10:51:26 EDT 2012
    Previous message: [Paraview] auto generated line edits in the display panel
    Next message: [Paraview] auto generated line edits in the display panel
    Messages sorted by: [ date ] [ thread ] [ subject ] [ author ]
I agree this is an issue. I think in the past for display properties
we relived on editingFinished(), I believe that could be a reasonable
choice still for properties under the display "Section". For the
non-display section, we could still use the current signal, or even if
we change that to editingFinished(), I wonder if that'd be a major
issue. Kyle?
Utkarsh
On Fri, Oct 19, 2012 at 9:21 PM, burlen <burlen.loring at gmail.com> wrote:
> Hi,
> I'm finding it at times problematic when making changes to line edits in the
> auto generated display properties panel, that the individual parts of the
> change triggers a render. For example, if I were to change a parameter from
> "1" to "0.005" there are 5 renders triggered (0, 0., 0.0, 0.00, 0.005). Of
> course it's no big deal when working locally with small data but it can be
> problematic when rendering takes along time. In other cases the intermediate
> values sent (eg the 4 values 0 to 0.00) are invalid and the render produces
> either nothing or the incorrect results until the final value is ready.
> At the same time it seems that in other cases it's a desirable thing for the
> auto-generated panels to respond immediately to changes for example to make
> apply button green. So I'm wondering, would it be possible to control this
> behavior with an xml attribute? for example by connecting to one or the
> other of the editingFinished or texteEdited signals? Or perhaps for the
> generation code to select which signal to connect to depending on the
> context?
> Since the properties panel is under development I thought it might be a good
> time to suggest such a change (-:
> Burlen
> _______________________________________________
> Powered by www.kitware.com
> Visit other Kitware open-source projects at
> http://www.kitware.com/opensource/opensource.html [^]
> Please keep messages on-topic and check the ParaView Wiki at:
> http://paraview.org/Wiki/ParaView [^]
> Follow this link to subscribe/unsubscribe:
> http://www.paraview.org/mailman/listinfo/paraview [^]
No tags attached.
Issue History
2013-02-17 14:04BurlenNew Issue
2013-02-18 09:56Kyle LutzAssigned To => Kyle Lutz
2013-02-18 09:56Kyle LutzStatusbacklog => todo
2013-02-18 10:18Kyle LutzStatustodo => active development
2013-02-21 09:01Kyle LutzTopic Name => 13887-avoid-spurious-render
2013-02-21 09:01Kyle LutzNote Added: 0030362
2013-02-21 09:01Kyle LutzStatusactive development => gatekeeper review
2013-02-21 09:01Kyle LutzResolutionopen => fixed
2013-02-22 13:19Sebastien JourdainStatusgatekeeper review => customer review
2013-02-22 13:19Sebastien JourdainNote Added: 0030371
2013-05-21 21:49Alan ScottNote Added: 0030821
2013-05-21 21:49Alan ScottStatuscustomer review => closed
Notes
(0030362)
Kyle Lutz
2013-02-21 09:01
Merge topic '13887-avoid-spurious-render' into next
1fe63f0 Avoid rendering each time a display property's text is changed
(0030371)
Sebastien Jourdain
2013-02-22 13:19
Merged into master
(0030821)
Alan Scott
2013-05-21 21:49
Developer's tag in git. Closing.
