MantisBT - ParaView |
View Issue Details |
0014148 | ParaView | (No Category) | public | 2013-06-26 10:29 | 2016-08-12 09:59 |
Reporter | Utkarsh Ayachit | |
Assigned To | Utkarsh Ayachit | |
Status | closed | Resolution | moved | |
Product Version | | |
Target Version | | Fixed in Version | | |
Project | TBD |
Topic Name | 14148_fix_path_issues |
Type | incorrect functionality |
Summary | 0014148: fix ParaView modules path on OsX when executable run from PATH. |
Description | Refer to this mail on mailing list for details:
http://www.paraview.org/pipermail/paraview/2013-June/028689.html [^] |
Steps To Reproduce | |
Additional Information | |
Tags | No tags attached. |
Attached Files | |
2013-06-26 10:29 | Utkarsh Ayachit | New Issue | |
2013-06-27 10:56 | Utkarsh Ayachit | Topic Name | => 14148_fix_path_issues |
2013-06-27 10:56 | Utkarsh Ayachit | Note Added: 0031089 | |
2013-06-27 10:56 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2013-06-27 10:56 | Utkarsh Ayachit | Fixed in Version | => git-next |
2013-06-27 10:56 | Utkarsh Ayachit | Resolution | open => fixed |
2013-06-27 10:56 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2013-06-28 08:38 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2013-06-28 08:39 | Utkarsh Ayachit | Note Added: 0031094 | |
2013-06-28 08:39 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-08-14 19:12 | Alan Scott | Note Added: 0031455 | |
2013-08-14 19:12 | Alan Scott | Status | customer review => closed |
2013-11-01 13:18 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
2014-10-16 13:59 | Miklem | Note Added: 0033656 | |
2014-10-16 13:59 | Miklem | Status | closed => backlog |
2014-10-16 13:59 | Miklem | Resolution | fixed => reopened |
2014-11-25 10:41 | Joe Borg | Note Added: 0033845 | |
2014-11-27 10:07 | Utkarsh Ayachit | Note Added: 0033853 | |
2015-01-11 08:24 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master e9452087 |
2015-01-11 08:24 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master de7bc247 |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038414 | |
2016-08-12 09:59 | Kitware Robot | Fixed in Version | 4.1 => |
2016-08-12 09:59 | Kitware Robot | Resolution | reopened => moved |
(0031089)
Utkarsh Ayachit
2013-06-27 10:56
commit de7bc247b3708e639e11384268853fa8b5579387
Date: Thu Jun 27 10:54:01 2013 -0400
BUG 0014148. Fix location of executable path.
When executable was run from PATH, we were not determining the executable path
correctly which was messing up the logic to find Python module paths. This fixes
that issue.
Change-Id: I1db76f3f5ca9b4e9b9de26f02584332689ef7632 |
(0031094)
Utkarsh Ayachit
2013-06-28 08:39
SUMMARY
Topics merged into master:
13791_sliceview_hide_outline
allow_request_data_to_fail
block-icon-cache
freeze_python
pvw-extend-pipeline-manager
pvw-fix-clip-widget
pvw-python-friendly-processRMIs
pvw-signal-handler-arg
simple-py-lookup-tables
(VTK) table2structured_one_piece_extent_fix
tecplot_extensions
(0031455)
Alan Scott
2013-08-14 19:12
Since I don't have a Mac build, trusting that this is correct. |
(0033656)
Miklem
2014-10-16 13:59
Hi, I just downloaded paraview 4.2 and have the same issues with python. For examle:
1) In home folder I ran python idle, and then 'import vtk', it's working, but if I ran 'from paraview.simple import *' it crashes with the error:
import paraview, re, os, os.path, new, sys, atexit, vtk
File "home/ParaView-4.2.0-Linux-64bit/lib/paraview-4.2/site-packages/paraview/vtk/__init__.py", line 7, in <module>
from vtkCommonCorePython import *
ImportError: No module named vtkCommonCorePython
2) if I go to home/ParaView-4.2.0-Linux-64bit/lib/paraview-4.2/site-packages/paraview, start python there and run 'import vtk' it crashes as well.
My config:
PYTHONPATH=/home/ParaView-4.2.0-Linux-64bit/lib/paraview-4.2/site-packages/:/home/ParaView-4.2.0-Linux-64bit/lib/paraview-4.2/:
LD_LIBRARY_PATH=/home/ParaView-4.2.0-Linux-64bit/lib/paraview-4.2/ |
(0033845)
Joe Borg
2014-11-25 10:41
@Miklem, have you tried adding
to the PYTHONPATH? vtkCommonCorePython.so is in there. |
(0033853)
Utkarsh Ayachit
2014-11-27 10:07
Note on OsX LD_LIBRARY_PATH is not used. You need to use DYLD_LIBRARY_PATH. |
(0038414)
Kitware Robot
2016-08-12 09:59
Resolving issue as `moved`.
This issue tracker is no longer used. Further discussion of this issue may take place in the current ParaView Issues page linked in the banner at the top of this page. |
