MantisBT - ParaView | |||||
View Issue Details | |||||
0014203 | ParaView | (No Category) | public | 2013-08-01 11:41 | 2016-08-12 09:59 |
Reporter | Jan Knaup | ||||
Product Version | 4.0 | ||||
Project | TBD | ||||
Topic Name | |||||
Type | crash | ||||
Summary | 0014203: Crash when trying to read XMOL .xyz files: cannot find elements.xml | ||||
Description | Found in ParaView-4.0.1-Linux-64bit, installed from binary distribution from paraview.org. When trying to open the enclosed XMOL .xyz file or any other file of the same type, the program crashed with the stack trace appended below. Apparently a file "elements.xml" is searched in a hard-coded absolute location instead of relative to the installation directory. Stack trace: ERROR: In /home/utkarsh/Dashboards/MyTests/NightlyMaster/ParaViewSuperbuild-Release/paraview/src/paraview/VTK/Domains/Chemistry/vtkBlueObeliskDataParser.cxx, line 68 vtkBlueObeliskDataParser (0x3196470): Cannot find elements.xml. Checked /home/utkarsh/Dashboards/MyTests/NightlyMaster/ParaViewSuperbuild-Release/install//vtkChemistry/vtkBODRData and /home/utkarsh/Dashboards/MyTests/NightlyMaster/ParaViewSuperbuild-Release/paraview/src/paraview/VTK/Domains/Chemistry ERROR: In /home/utkarsh/Dashboards/MyTests/NightlyMaster/ParaViewSuperbuild-Release/paraview/src/paraview/VTK/IO/XMLParser/vtkXMLParser.cxx, line 382 vtkBlueObeliskDataParser (0x3196470): Parse() called with no Stream set. Segmentation fault (core dumped) | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | ![]() https://www.vtk.org/Bug/file/9492/trajectory.0000000000.xyz | ||||
Issue History | |||||
2013-08-01 11:41 | Jan Knaup | New Issue | |||
2013-08-01 11:41 | Jan Knaup | File Added: trajectory.0000000000.xyz | |||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038429 | |||
Notes | |||||
