MantisBT - ParaView | |||||
| View Issue Details | |||||
| 0014992 | ParaView | (No Category) | public | 2014-09-11 10:28 | 2016-08-12 09:59 |
| Reporter | Cory Quammen | ||||
| Assigned To | Cory Quammen | ||||
| Priority | normal | Severity | minor | Reproducibility | have not tried |
| Status | closed | Resolution | moved | ||
| Product Version | 4.2 | ||||
| Target Version | Fixed in Version | ||||
| Project | Sandia | ||||
| Topic Name | |||||
| Type | incorrect functionality | ||||
| Summary | 0014992: vtkSMDomain::SetDefaultValues() overrides custom setting defaults in some cases | ||||
| Description | In particular, this makes it impossible to set the default representation type for GeometryRepresentation with the following JSON: "representations" : { "GeometryRepresentation" : { "Representation" : "Surface With Edges" } } The reason is that custom default values are set prior to domains being reset. Some domains, such as vtkSMBooleanDomain, do nothing in SetDefaultValues(). Others, such as vtkSMRepresentationTypeDomain, change property values. | ||||
| Steps To Reproduce | |||||
| Relationships | |||||
| Attached Files | |||||
| Issue History | |||||
| 2014-09-11 10:28 | Cory Quammen | New Issue | |||
| 2014-09-11 10:28 | Cory Quammen | Assigned To | => Cory Quammen | ||
| 2016-08-12 09:59 | Kitware Robot | Note Added: 0038654 | |||
| 2016-08-12 09:59 | Kitware Robot | Status | backlog => closed | ||
| 2016-08-12 09:59 | Kitware Robot | Resolution | open => moved | ||
| Notes | |||||
