MantisBT - ParaView
View Issue Details
0015340ParaView(No Category)public2015-02-23 16:212016-08-12 09:59
Alan Scott
Alvaro Sanchez
normalminorhave not tried
closedmoved
git-master
Sandia
incorrect functionality
0015340: Volume rendering vectors doesn't work correctly.
Volume rendering vectors doesn't work correctly. Please fix it.
* Master, Linux, local server.
* Open disk_out_ref.exo. All vars on. Apply.
* Just to show what this should look like, run a calculator filter. Formula is mag(V). Apply. +X. Now, color by Result, and volume render. This is correct.
* Turn visibility off for the Calculator, turn visibility on for disk_out_ref.exo.
* Color by V, Magnitude. Volume render. This is a bug.
* Click on +Z. Now, start coloring by the different components of V - i.e., X, Y and Z. X and Y look the same, but I am fairly sure should be different. This is a bug.
No tags attached.
related to 0015339closed Kitware Robot Map Scalars doesn't work with volume rendering
has duplicate 0014242closed Alvaro Sanchez Cannot volume rendering using vectors
Issue History
2015-02-23 16:21Alan ScottNew Issue
2015-02-23 16:21Alan ScottRelationship addedrelated to 0015339
2015-02-23 16:25Alan ScottRelationship addedhas duplicate 0014242
2016-07-12 11:41Utkarsh AyachitAssigned To => Alvaro Sanchez
2016-08-12 09:59Kitware RobotNote Added: 0038778
2016-08-12 09:59Kitware RobotStatusbacklog => closed
2016-08-12 09:59Kitware RobotResolutionopen => moved
Notes
(0038778)
Kitware Robot
2016-08-12 09:59
Resolving issue as `moved`.
