MantisBT - VTK | |||||
View Issue Details | |||||
0015545 | VTK | (No Category) | public | 2015-06-16 14:20 | 2016-08-12 09:55 |
Reporter | Edson Tadeu M. Manoel | ||||
Priority | high | Severity | minor | Reproducibility | always |
Product Version | 6.0.0 | ||||
Project | TBD | ||||
Type | crash | ||||
Summary | 0015545: Observer crashes with Python thread, bug in vtkPythonCommand and also in dataset_adapter | ||||
Description | Currently, if an observer is added in a python thread and then executed in another thread after the first one has finished, it will cause a segfault/access violation in the python interpreter. This code reproduces the problem: from Queue import Queue from threading import Thread import vtk def on_delete(caller, event): print 'on_delete:' print ' caller:', caller print ' event:', event def create_object_with_observer(result_queue): object_with_observer = vtk.vtkObject() object_with_observer.AddObserver('DeleteEvent', on_delete) result_queue.put(object_with_observer) def test_observer_command_with_threads(): result_queue = Queue() thread = Thread(target=create_object_with_observer, args=(result_queue,)) thread.start() thread.join() object_with_observer = result_queue.get(block=True) print object_with_observer del object_with_observer # <-- crashes here print 'checkpoint' if __name__ == '__main__': test_observer_command_with_threads() This seems to happen because of this line in vtkPythonCommand.cxx, which seems to be assigning a bad ThreadState pointer to _PyThreadState_Current: prevThreadState = PyThreadState_Swap(this->ThreadState); (The pointer seems to be dangling. Perhaps vtkPythonCommand::SetThreadState should incref the PyThreadState* object?) This bug is directly affecting dataset_adapter, because it causes a crash in this use case (dataset_adapter uses a command to store the numpy array ref): from Queue import Queue from threading import Thread from vtk.numpy_interface.dataset_adapter import UnstructuredGrid import numpy import vtk def create_unstructured_grid(result_queue): points = numpy.array([[0.0, 0.0, 0.0]]) ug = UnstructuredGrid(vtk.vtkUnstructuredGrid()) ug.SetPoints(points) result_queue.put(ug) def test_unstructured_grid_in_thread(): result_queue = Queue() thread1 = Thread(target=create_unstructured_grid, args=(result_queue,)) thread1.start() thread1.join() ug = result_queue.get(block=True) print ug del ug # <-- crashes print 'checkpoint' if __name__ == '__main__': test_unstructured_grid_in_thread() | ||||
Steps To Reproduce | I was able to reproduce the problem with the supplied test program. Also, I replaced the DeleteEvent with UserEvent, and it still crashed: print object_with_observer object_with_observer.InvokeEvent(vtk.vtkCommand.UserEvent) # <-- crashes here print 'checkpoint' Crash occurred in vtkPythonCommand.cxx line 222: 219 arglist = Py_BuildValue((char*)"(Ns)", obj2, eventname); 220 } 221 -> 222 PyObject *result = PyEval_CallObject(this->obj, arglist); 223 Py_DECREF(arglist); 224 225 if (result) | ||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2015-06-16 14:20 | Edson Tadeu M. Manoel | New Issue | |||
2015-06-17 10:01 | David Gobbi | Reproducibility | have not tried => always | ||
2015-06-17 10:01 | David Gobbi | Steps to Reproduce Updated | bug_revision_view_page.php?rev_id=1116#r1116 | ||
2016-07-06 16:47 | Berk Geveci | Status | backlog => expired | ||
2016-08-12 09:55 | Kitware Robot | Note Added: 0037395 | |||
2016-08-12 09:55 | Kitware Robot | Status | expired => closed | ||
2016-08-12 09:55 | Kitware Robot | Resolution | open => moved | ||
2016-08-12 09:55 | Kitware Robot | Assigned To | => Kitware Robot |
Notes | |||||
