MantisBT - ParaView | |||||
| View Issue Details | |||||
| 0015763 | ParaView | (No Category) | public | 2015-10-08 19:26 | 2015-12-16 17:11 |
| Reporter | Alan Scott | ||||
| Assigned To | Utkarsh Ayachit | ||||
| Priority | urgent | Severity | crash | Reproducibility | have not tried |
| Status | closed | Resolution | fixed | ||
| Product Version | 4.4 | ||||
| Target Version | 5.0 | Fixed in Version | 5.0 | ||
| Project | Sandia | ||||
| Topic Name | |||||
| Type | incorrect functionality | ||||
| Summary | 0015763: Crash remote server | ||||
| Description | PV 4.4.0 has a bad crash remote server. This one appears hard to replicate. Here is a way to replicate it every time. Note to myself - Dataset is under arne's directory. * Blow away your .config files. (Not sure of --dr works, I assume it would.) * Linux, 4.4.0, remote server (16 processes). (Note to myself - Chama, 1 node) * Open deep_target.g.100.[000-099]. Apply. * Right click on the cylendar. Rotate the dataset UP about 60 degrees, so that you mainly see the yellow box, but can still see the blue stuff inside of the box. * Right click on the yellow box. This will work. * Left click somewhere in the gray background, bringing down the menu. * Right click on the blue stuff in the box. Seg faults on the server side. ERROR: In /projects/viz/paraview/src/ParaView/4.4.0/ParaView4/VTK/Parallel/Core/vtkSocketCommunicator.cxx, line 875 vtkSocketCommunicator (0x1601800): Tag mismatch: got 1, expecting 22222. ERROR: In /projects/viz/paraview/src/ParaView/4.4.0/ParaView4/ParaViewCore/ClientServerCore/Rendering/vtkPVSynchronizedRenderWindows.cxx, line 1125 vtkPVSynchronizedRenderWindows (0xf37d60): Mismatch is render windows on different processes. Aborting for debugging purposes. [chama32:14983] *** Process received signal *** [chama32:14983] Signal: Aborted (6) [chama32:14983] Signal code: (-6) [chama32:14983] [ 0] /lib64/libpthread.so.0(+0xf710) [0x2aaab1fbb710] [chama32:14983] [ 1] /lib64/libc.so.6(gsignal+0x35) [0x2aaab3e2e625] [chama32:14983] [ 2] /lib64/libc.so.6(abort+0x175) [0x2aaab3e2fe05] [chama32:14983] [ 3] /projects/viz/paraview/ParaView/4.4.0-Mesa/Linux-chama-x86_64/lib/paraview-4.4/libvtkPVClientServerCoreRendering-pv4.4.so.1(_ZN30vtkPVSynchronizedRenderWindows19LoadWindowAndLayoutEP15vtkRenderWindowR21vtkMultiProcessStream+0x3d1) [0x2aaab8e2a781] [chama32:14983] [ 4] /projects/viz/paraview/ParaView/4.4.0-Mesa/Linux-chama-x86_64/lib/paraview-4.4/libvtkPVClientServerCoreRendering-pv4.4.so.1(_ZN30vtkPVSynchronizedRenderWindows15RootStartRenderEP15vtkRenderWindow+0x54) [0x2aaab8e29f04] [chama32:14983] [ 5] /projects/viz/paraview/ParaView/4.4.0-Mesa/Linux-chama-x86_64/lib/paraview-4.4/libvtkPVClientServerCoreRendering-pv4.4.so.1(_ZN30vtkPVSynchronizedRenderWindows17HandleStartRenderEP15vtkRenderWindow+0x3b) [0x2aaab8e29b3b] [chama32:14983] [ 6] /projects/viz/paraview/ParaView/4.4.0-Mesa/Linux-chama-x86_64/lib/paraview-4.4/libvtkPVClientServerCoreRendering-pv4.4.so.1(+0xea48d) [0x2aaab8e2c48d] [chama32:14983] [ 7] /projects/viz/paraview/ParaView/4.4.0-Mesa/Linux-chama-x86_64/lib/paraview-4.4/libvtkCommonCore-pv4.4.so.1(+0x2bd799) [0x2aaab28d6799] [chama32:14983] [ 8] /projects/viz/paraview/ParaView/4.4.0-Mesa/Linux-chama-x86_64/lib/paraview-4.4/libvtkCommonCore-pv4.4.so.1(_ZN9vtkObject11InvokeEventEmPv+0x12) [0x2aaab28d63e2] [chama32:14983] [ 9] /projects/viz/paraview/ParaView/4.4.0-Mesa/Linux-chama-x86_64/lib/paraview-4.4/libvtkRenderingCore-pv4.4.so.1(_ZN15vtkRenderWindow6RenderEv+0x69) [0x2aaaad2066d9] [chama32:14983] [10] /projects/viz/paraview/ParaView/4.4.0-Mesa/Linux-chama-x86_64/lib/paraview-4.4/libvtkRenderingCore-pv4.4.so.1(_ZN19vtkHardwareSelector14CaptureBuffersEv+0xf7) [0x2aaaad1b83a7] [chama32:14983] [11] /projects/viz/paraview/ParaView/4.4.0-Mesa/Linux-chama-x86_64/lib/paraview-4.4/libvtkPVClientServerCoreRendering-pv4.4.so.1(_ZN21vtkPVHardwareSelector13PrepareSelectEv+0x63) [0x2aaab8dfd443] [chama32:14983] [12] /projects/viz/paraview/ParaView/4.4.0-Mesa/Linux-chama-x86_64/lib/paraview-4.4/libvtkPVClientServerCoreRendering-pv4.4.so.1(_ZN21vtkPVHardwareSelector6SelectEPi+0x15) [0x2aaab8dfd2e5] [chama32:14983] [13] /projects/viz/paraview/ParaView/4.4.0-Mesa/Linux-chama-x86_64/lib/paraview-4.4/libvtkPVClientServerCoreRendering-pv4.4.so.1(_ZN15vtkPVRenderView6SelectEiPi+0x72) [0x2aaab8e1ae72] [chama32:14983] [14] /projects/viz/paraview/ParaView/4.4.0-Mesa/Linux-chama-x86_64/lib/paraview-4.4/libvtkPVClientServerCoreRendering-pv4.4.so.1(_ZN15vtkPVRenderView11SelectCellsEPi+0xe) [0x2aaab8e1adfe] [chama32:14983] [15] /projects/viz/paraview/ParaView/4.4.0-Mesa/Linux-chama-x86_64/lib/paraview-4.4/libvtkPVServerManagerApplication-pv4.4.so.1(_Z22vtkPVRenderViewCommandP26vtkClientServerInterpreterP13vtkObjectBasePKcRK21vtkClientServerStreamRS5_Pv+0x54ed) [0x2aaaab75235d] [chama32:14983] [16] /projects/viz/paraview/ParaView/4.4.0-Mesa/Linux-chama-x86_64/lib/paraview-4.4/libvtkClientServer-pv4.4.so.1(_ZN26vtkClientServerInterpreter19CallCommandFunctionEPKcP13vtkObjectBaseS1_RK21vtkClientServerStreamRS4_+0xe5) [0x2aaaaf733f85] [chama32:14983] [17] /projects/viz/paraview/ParaView/4.4.0-Mesa/Linux-chama-x86_64/lib/paraview-4.4/libvtkClientServer-pv4.4.so.1(_ZN26vtkClientServerInterpreter20ProcessCommandInvokeERK21vtkClientServerStreami+0x131) [0x2aaaaf733851] [chama32:14983] [18] /projects/viz/paraview/ParaView/4.4.0-Mesa/Linux-chama-x86_64/lib/paraview-4.4/libvtkClientServer-pv4.4.so.1(_ZN26vtkClientServerInterpreter17ProcessOneMessageERK21vtkClientServerStreami+0x18d) [0x2aaaaf7328fd] [chama32:14983] [19] /projects/viz/paraview/ParaView/4.4.0-Mesa/Linux-chama-x86_64/lib/paraview-4.4/libvtkClientServer-pv4.4.so.1(_ZN26vtkClientServerInterpreter13ProcessStreamERK21vtkClientServerStream+0x29) [0x2aaaaf733e69] [chama32:14983] [20] /projects/viz/paraview/ParaView/4.4.0-Mesa/Linux-chama-x86_64/lib/paraview-4.4/libvtkPVServerImplementationCore-pv4.4.so.1(_ZN16vtkPVSessionCore21ExecuteStreamInternalERK21vtkClientServerStreamb+0xab) [0x2aaaac6b564b] [chama32:14983] [21] /projects/viz/paraview/ParaView/4.4.0-Mesa/Linux-chama-x86_64/lib/paraview-4.4/libvtkPVServerImplementationCore-pv4.4.so.1(_ZN16vtkPVSessionCore13ExecuteStreamEjRK21vtkClientServerStreamb+0x66) [0x2aaaac6b3356] [chama32:14983] [22] /projects/viz/paraview/ParaView/4.4.0-Mesa/Linux-chama-x86_64/lib/paraview-4.4/libvtkPVServerImplementationCore-pv4.4.so.1(_ZN16vtkPVSessionBase13ExecuteStreamEjRK21vtkClientServerStreamb+0x30) [0x2aaaac6b13b0] [chama32:14983] [23] /projects/viz/paraview/ParaView/4.4.0-Mesa/Linux-chama-x86_64/lib/paraview-4.4/libvtkPVServerImplementationCore-pv4.4.so.1(_ZN18vtkPVSessionServer24OnClientServerMessageRMIEPvi+0x2c3) [0x2aaaac6bbd73] [chama32:14983] [24] /projects/viz/paraview/ParaView/4.4.0-Mesa/Linux-chama-x86_64/lib/paraview-4.4/libvtkPVServerImplementationCore-pv4.4.so.1(+0x47aa6) [0x2aaaac6bbaa6] [chama32:14983] [25] /projects/viz/paraview/ParaView/4.4.0-Mesa/Linux-chama-x86_64/lib/paraview-4.4/libvtkParallelCore-pv4.4.so.1(_ZN25vtkMultiProcessController10ProcessRMIEiPvii+0xa8) [0x2aaab04606d8] [chama32:14983] [26] /projects/viz/paraview/ParaView/4.4.0-Mesa/Linux-chama-x86_64/lib/paraview-4.4/libvtkParallelCore-pv4.4.so.1(_ZN25vtkMultiProcessController11ProcessRMIsEii+0x13f) [0x2aaab04601ef] [chama32:14983] [27] /projects/viz/paraview/ParaView/4.4.0-Mesa/Linux-chama-x86_64/lib/paraview-4.4/libvtkPVClientServerCoreCore-pv4.4.so.1(_ZN26vtkTCPNetworkAccessManager21ProcessEventsInternalEmb+0x202) [0x2aaaac9cde32] [chama32:14983] [28] /projects/viz/paraview/ParaView/4.4.0-Mesa/Linux-chama-x86_64/lib/paraview-4.4/libvtkPVClientServerCoreCore-pv4.4.so.1(_ZN26vtkTCPNetworkAccessManager13ProcessEventsEm+0xb) [0x2aaaac9cdc2b] [chama32:14983] [29] /projects/viz/paraview/ParaView/4.4.0-Mesa/Linux-chama-x86_64/lib/paraview-4.4/pvserver(main+0x1f4) [0x404014] [chama32:14983] *** End of error message *** | ||||
| Steps To Reproduce | |||||
| Relationships | |||||
| Attached Files | |||||
| Issue History | |||||
| 2015-10-08 19:26 | Alan Scott | New Issue | |||
| 2015-10-08 19:27 | Alan Scott | Target Version | => 5.0 | ||
| 2015-10-08 19:35 | Alan Scott | Description Updated | bug_revision_view_page.php?rev_id=1328#r1328 | ||
| 2015-10-08 19:46 | Alan Scott | Priority | normal => urgent | ||
| 2015-10-08 19:46 | Alan Scott | Severity | minor => crash | ||
| 2015-10-09 10:17 | Utkarsh Ayachit | Note Added: 0035269 | |||
| 2015-10-09 10:19 | Utkarsh Ayachit | Note Added: 0035270 | |||
| 2015-10-09 20:31 | Alan Scott | Note Added: 0035271 | |||
| 2015-10-13 17:02 | Utkarsh Ayachit | Note Added: 0035280 | |||
| 2015-10-13 17:02 | Utkarsh Ayachit | Status | backlog => customer review | ||
| 2015-10-13 17:02 | Utkarsh Ayachit | Fixed in Version | => git-master | ||
| 2015-10-13 17:02 | Utkarsh Ayachit | Resolution | open => fixed | ||
| 2015-10-13 17:02 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit | ||
| 2015-10-28 09:29 | Utkarsh Ayachit | Fixed in Version | git-master => 5.0 | ||
| 2015-12-01 20:27 | Alan Scott | Note Added: 0035510 | |||
| 2015-12-01 20:27 | Alan Scott | Status | customer review => todo | ||
| 2015-12-08 08:33 | Utkarsh Ayachit | Note Added: 0035520 | |||
| 2015-12-08 09:55 | Utkarsh Ayachit | Note Added: 0035521 | |||
| 2015-12-08 09:55 | Utkarsh Ayachit | Status | todo => gatekeeper review | ||
| 2015-12-09 04:03 | Utkarsh Ayachit | Status | gatekeeper review => customer review | ||
| 2015-12-16 17:11 | Alan Scott | Note Added: 0035582 | |||
| 2015-12-16 17:11 | Alan Scott | Status | customer review => closed | ||
| Notes | |||||
