MantisBT - ParaView | |||||
| View Issue Details | |||||
| 0016079 | ParaView | (No Category) | public | 2016-04-19 11:07 | 2016-08-12 10:00 |
| Reporter | Ken Moreland | ||||
| Assigned To | T.J. Corona | ||||
| Priority | normal | Severity | minor | Reproducibility | have not tried |
| Status | closed | Resolution | moved | ||
| Product Version | 5.0 | ||||
| Target Version | 5.1 | Fixed in Version | |||
| Project | Sandia | ||||
| Topic Name | |||||
| Type | incorrect functionality | ||||
| Summary | 0016079: Possible negative magnitude when coloring by vectors with angular periodic filter | ||||
| Description | The range on the color bar sometimes gives strange results when using the Angular Periodic Filter. In particular it is possible to get negative values for a vector magnitude. To replicate, do the following. 1. Create a plane source. Origin = [0,0,0], Point1 = [1,0,0], Point2 = [0,1,0]. Apply. 2. Add the calculator filter. Make the expression "coords" (just the point coordinates). Apply. 3. Add Angular Periodic Filter. Rotation Angle = 90. Axis = Z. Apply. 4. Color by "Result" and "Magnitude" Note that the range of the magnitude starts at -1, which is clearly wrong. | ||||
| Steps To Reproduce | |||||
| Relationships | |||||
| Attached Files | |||||
| Issue History | |||||
| 2016-04-19 11:07 | Ken Moreland | New Issue | |||
| 2016-04-19 13:24 | Alan Scott | Project | TBD => Sandia | ||
| 2016-04-19 13:24 | Alan Scott | Target Version | => 5.1 | ||
| 2016-06-21 08:17 | T.J. Corona | Assigned To | => T.J. Corona | ||
| 2016-06-21 08:22 | T.J. Corona | Note Added: 0036088 | |||
| 2016-06-21 08:22 | T.J. Corona | Status | backlog => gatekeeper review | ||
| 2016-06-21 08:22 | T.J. Corona | Resolution | open => fixed | ||
| 2016-08-12 10:00 | Kitware Robot | Note Added: 0039035 | |||
| 2016-08-12 10:00 | Kitware Robot | Status | gatekeeper review => closed | ||
| 2016-08-12 10:00 | Kitware Robot | Resolution | fixed => moved | ||
| Notes | |||||
