MantisBT - ParaView | |||||
| View Issue Details | |||||
| 0016767 | ParaView | (No Category) | public | 2016-07-01 11:15 | 2016-08-12 10:00 |
| Reporter | Mathieu Westphal | ||||
| Assigned To | Mathieu Westphal | ||||
| Priority | normal | Severity | minor | Reproducibility | have not tried |
| Status | closed | Resolution | moved | ||
| Product Version | git-master | ||||
| Target Version | Fixed in Version | ||||
| Project | TBD | ||||
| Topic Name | |||||
| Type | incorrect functionality | ||||
| Summary | 0016767: RenderView management with python segfault | ||||
| Description | There is a systematic segfault with the following code in pvpython : Basically, Creating and rendering a first view, then Creating and rendering a second render view, then destroying the first view, will put the second in a unstable state that will lead to a segfault. Does not reproduce in paraview. | ||||
| Steps To Reproduce | from paraview.simple import * import gc v=CreateRenderView() Render(v) w=CreateRenderView() Render(w) Delete(v) del v gc.collect() # not absolutally necessary, the destructor will be called eventually Render(w) [xcb] Unknown sequence number while appending request [xcb] Most likely this is a multi-threaded client and XInitThreads has not been called [xcb] Aborting, sorry about that. pvpython: xcb_io.c:161: append_pending_request: Assertion `!xcb_xlib_unknown_seq_number' failed. Aborted (core dumped) | ||||
| Relationships | |||||
| Attached Files | https://www.vtk.org/Bug/file/10135/bugRender.py | ||||
| Issue History | |||||
| 2016-07-01 11:15 | Mathieu Westphal | New Issue | |||
| 2016-07-01 11:15 | Mathieu Westphal | Assigned To | => Mathieu Westphal | ||
| 2016-07-01 11:15 | Mathieu Westphal | Description Updated | bug_revision_view_page.php?rev_id=1641#r1641 | ||
| 2016-07-01 11:15 | Mathieu Westphal | Steps to Reproduce Updated | bug_revision_view_page.php?rev_id=1643#r1643 | ||
| 2016-07-01 11:17 | Mathieu Westphal | File Added: bugRender.py | |||
| 2016-08-12 10:00 | Kitware Robot | Note Added: 0039083 | |||
| 2016-08-12 10:00 | Kitware Robot | Status | backlog => closed | ||
| 2016-08-12 10:00 | Kitware Robot | Resolution | open => moved | ||
| Notes | |||||
