MantisBT - ParaView
View Issue Details
0006035ParaView(No Category)public2007-11-09 14:282009-05-13 13:59
David Karelitz
Berk Geveci
highcrashalways
closedduplicate
3.43.4
0006035: (MARS-immediate) 0th process using too much memory
When opening and performing operations on a large CTH AMR dataset, the 0th node uses way too much memory. Order 3-4 GB on the 0th node vs 640 MB on other nodes. There was a CTH reader, CellToPoint, Contour, Calculator, TimeToText, and TextSource in the pipeline and we tried to save a movie and disconnect.
No tags attached.
duplicate of 0006773closed Utkarsh Ayachit Use Broadcast to propagate commands from root sever node to other server nodes
Issue History
2007-11-09 14:28David KarelitzNew Issue
2007-11-15 16:45David KarelitzNote Added: 0009690
2007-11-15 16:50David KarelitzNote Added: 0009691
2007-11-19 18:19David KarelitzSummary0th process using too much memory => (MARS-immediate) 0th process using too much memory
2007-12-05 13:13Alan ScottStatusbacklog => tabled
2007-12-05 13:13Alan ScottAssigned To => Berk Geveci
2008-01-10 11:11David KarelitzNote Added: 0010104
2008-03-07 07:56Berk GeveciTarget Version => MARS
2008-03-07 08:03Berk GeveciCategory => 3.4
2008-04-08 13:01Ken MorelandRelationship addedduplicate of 0006773
2008-04-08 13:02Ken MorelandDuplicate ID0 => 6773
2008-04-08 13:02Ken MorelandStatustabled => @80@
2008-04-08 13:02Ken MorelandResolutionopen => duplicate
2008-04-08 13:02Ken MorelandNote Added: 0011159
2008-04-08 17:56Alan ScottStatus@80@ => closed
2008-04-08 17:56Alan ScottNote Added: 0011188
2009-05-13 13:58Utkarsh AyachitTarget VersionMARS => 3.4
2009-05-13 13:59Utkarsh AyachitFixed in Version => 3.4
2011-06-16 13:10Zack GalbreathCategory => (No Category)
Notes
(0009690)
David Karelitz
2007-11-15 16:45
There appear to be 2 issues with respect to memory usage. These are from a separate run than that in the description
1. When I clip by scalar value with an incorrect value (that results in more elements than the correct value), the memory is not released for the first incorrect clip value.
2. When I choose save and disconnect, memory usage on the 0th node jumps from 33% to 85% and uses an additional 2-4% per frame. This is on an 8 GB machine.
The dataset is AMRCTH running on 120 nodes
(0009691)
David Karelitz
2007-11-15 16:50
It's 4 GB of memory per node, not 8GB
(0010104)
David Karelitz
2008-01-10 11:11
When we switched the 0th node to a node with 12GB of memory, performance was an order of magnitude faster. The rest of the nodes were the same as before
(0011159)
Ken Moreland
2008-04-08 13:02
This problem is really caused by a bug in OpenMPI and the way that messages are passed from node 0 to the rest of the nodes. I opened a new bug that more specifically addresses the problem.
(0011188)
Alan Scott
2008-04-08 17:56
I agree with ken. This is an open mpi bug, not related to the bug description listed below. Solution is th change MPI_Send to MPI_Ssend, until the bug in the OpenMPI library is fixed. I believe the file is MPICommunication.cxx or something like that.
