MantisBT - ParaView
View Issue Details
0006217ParaView(No Category)public2008-01-04 16:242009-05-13 13:46
David Karelitz
Ken Moreland
normalfeaturealways
closedfixed
3.6
0006217: (MARS-low) Add tickmarks to scalar bar widget
The scalar bar widget should have tick marks that indicate whether it's showing a linear or log-scale
No tags attached.
png ScalarBarTicMockup.png (181,461) 2008-04-17 17:12
https://www.vtk.org/Bug/file/6415/ScalarBarTicMockup.png
png
png niceTics.png (12,199) 2008-04-22 10:14
https://www.vtk.org/Bug/file/6424/niceTics.png
png
tgz ticmarks.tgz (1,540) 2008-04-22 10:14
https://www.vtk.org/Bug/file/6425/ticmarks.tgz
Issue History
2008-01-04 16:24David KarelitzNew Issue
2008-03-07 07:56Berk GeveciTarget Version => MARS
2008-03-07 08:03Berk GeveciCategoryDevelopment => 3.4
2008-04-09 16:12Ken MorelandStatusbacklog => tabled
2008-04-09 16:12Ken MorelandAssigned To => Ken Moreland
2008-04-14 14:10Ken MorelandNote Added: 0011286
2008-04-17 17:12David Thompson (old)File Added: ScalarBarTicMockup.png
2008-04-17 17:14David Thompson (old)Note Added: 0011418
2008-04-22 10:14Ken MorelandFile Added: niceTics.png
2008-04-22 10:14Ken MorelandFile Added: ticmarks.tgz
2008-04-22 10:18Ken MorelandNote Added: 0011475
2008-05-29 13:26Berk GeveciCategory3.4 => 3.6
2008-11-25 09:29Ken MorelandNote Added: 0014175
2008-11-25 09:29Ken MorelandStatustabled => @80@
2008-11-25 09:29Ken MorelandResolutionopen => fixed
2008-12-04 21:59Alan ScottNote Added: 0014296
2008-12-04 21:59Alan ScottStatus@80@ => @20@
2008-12-04 21:59Alan ScottResolutionfixed => reopened
2009-02-17 13:12Ken MorelandNote Added: 0015030
2009-02-17 13:12Ken MorelandStatus@20@ => @80@
2009-02-17 13:12Ken MorelandResolutionreopened => fixed
2009-02-17 21:48Alan ScottNote Added: 0015121
2009-02-17 21:48Alan ScottStatus@80@ => closed
2009-05-13 13:46Utkarsh AyachitTarget VersionMARS => 3.6
2011-06-16 13:10Zack GalbreathCategory => (No Category)
Notes
(0011286)
Ken Moreland
2008-04-14 14:10
I'm hesitant to implement this. I can think of multiple approaches, but they all have issues.
1. Divide the region between labels evenly and place tick marks there. Unfortunately, this means the value at each tick has no obvious value. This can be especially confusing if the range (or its log) is divisible by 10 but the tick marks do not line up in decimal increments.
2. Ignore labels and place ticks at regions at some decimal length. This means that the ticks will not line up with the labels and create even more confusion.
3. Adjust the labels so that fall on tick marks lined up with decimal increments. This issue with that is that the labels no longer reflect the actual range of the data (or at least the mapping), which I feel is an important cue. You could fix that by...
4. setting the top and bottom labels at the top and bottom of the range but adjusting all the mid labels to the tick marks. Ignoring the issue with the top and bottom tick marks lining up, there is still an issue with the number of labels being used. Assuming the range size is at (or close to) some multiple of 10, your choices for the number of ticks (that line up on decimals) are 2, 5, or some multiple of those. 2 is too few, you basically get a middle value and that's it. 5 is too many; the font would have to be too small to see on anything but a full screen image, and you don't even get the middle value.
(0011418)
2008-04-17 17:14
The attached picture has tic marks rendered in black with additional yellow marks showing the location of the text label values. The top scalar bar is logarithmic. The lower is linear.
(0011475)
Ken Moreland
2008-04-22 10:18
Dave T. has come up with an even better solution for the tickmarks. The idea is to put the range labels above and below the bar and then scale the tickmarks such that they have nice spacing throughout the rest of the scalar bar (see the niceTics.png attachment). He has also made several algorithms to determine the appropriate spacing, written as readable MATLAB/Octave files, attached in tickmarks.tgz. There are also some plotting routines in there.
(0014175)
Ken Moreland
2008-11-25 09:29
/cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVScalarBarActor.cxx,v <-- Servers/Filters/vtkPVScalarBarActor.cxx
new revision: 1.6; previous revision: 1.5
/cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVScalarBarActor.h,v <-- Servers/Filters/vtkPVScalarBarActor.h
new revision: 1.4; previous revision: 1.3
/cvsroot/ParaView3/ParaViewData/Baseline/ColorEditor1.png,v <-- ColorEditor1.png
new revision: 1.3; previous revision: 1.2
/cvsroot/ParaView3/ParaViewData/Baseline/ExtractLevel.png,v <-- ExtractLevel.png
/cvsroot/ParaView3/ParaViewData/Baseline/ProxyPropertyLinks.png,v <-- ProxyPropertyLinks.png
(0014296)
Alan Scott
2008-12-04 21:59
Close, but not quite.
The tick marks should follow the color of the Color Scale Editor/ Color Legend/ Labels / Color, if possible. If this is hard, the current ticks are actually a pretty good color (they show OK on a default, white or black background).
(0015030)
Ken Moreland
2009-02-17 13:12
Tick colors now (closely) follow label colors (instead of the widget color, which nothing was using).
(0015121)
Alan Scott
2009-02-17 21:48
Excellent. Tested local server.
